Settings Tab/Knobs
Am using Xplane 11. Have started to work with some knobs. Have had some success with setting CW and CWW bespokes. When I test them in detective they work perfectly. Back in the sim when assigned to a knob they bounce around rather than consistently move from position to position.
I'm guessing one of the settings from the Settings page might help???
Any suggestions appreciated.
Dave
  • Commands are processed within X-Plane so they always have up-to-date DataRefs to run against. Bespoke Events run outside of X-Plane and access DataRefs via a shared memory area between GIT and the GIT plugin.
    So when a task sends an update to a DataRef, the command is processed by the plugin and then the shared memory area is updated. This happens extremely fast but there is a delay non the less.
    The Rotate function is also operating extremely fast so many of the task updates on a DataRef are actually just setting the DataRef to the same value because the shared memory area has not yet been updated.
    The trick is to add a Sleep task before or after the Set task to give the GIT Plugin chance to update shared memory. You want the Sleep task to use a very small number (its in milliseconds), so try a few values until it works better
