202 and can't connect with ngx.
1. I get error 202 please help.
2. I have some problem with PMDG737 It's can't connect with the plane. have any recommend?
Thank you.
Thank you.
For the NGX problem see the FAQ entry "My MCP PRO or MCP Advanced is not updating its display (just showing zeroes)" here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/70-faq-goflight-interface-tool.html
22:34:43 GoFlight Connection Starting.....
22:34:43 SimConnect Connection Starting.....
22:34:44 GoFlight Connection Started
22:35:13 SimConnect Message Processing Started
22:35:14 SimConnect Connection Started
22:35:14 Aircraft Connection Starting.....
22:35:15 SimConnect: Event Received: Start
22:35:15 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
22:35:15 SimConnect: Event Received: SIM, 0
22:35:15 SimConnect: Event Received: PAUSE, 0
22:35:16 WinSock: Connected To localhost On Port 27015!
22:35:16 LUA Processor: Started!
22:35:18 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
22:35:18 Aircraft Connection Started
22:35:18 Simconnect Version: 4.0.0.0
22:35:18 Aircraft FullName: IRIS Raptor Driver
22:35:18 Synchronising Switches & Selectors .....
22:35:18 Synchronising Switches & Selectors: Waiting for SimConnect .....
22:35:28 PMDG SDK option is OK in Prepar3D v4
22:35:28 SimConnect: Event Received: Aircraft Type Changed
22:35:28 GoFlight Connection Starting.....
22:35:28 SimConnect Message Processing Finished
22:35:29 SimConnect Connection Starting.....
22:35:29 Creating Bespoke Vars
22:35:29 Bespoke Vars Created
22:35:29 Importing Bespoke Variables
22:35:29 Bespoke Vars Assigned, Importing Bespoke Events
22:35:29 Bespoke Events Temp Imported
22:35:29 Bespoke Events Imported
22:35:30 GoFlight Connection Started
22:35:30 SimConnect Message Processing Started
22:35:30 SimConnect Connection Started
22:35:30 Aircraft Connection Starting.....
22:35:31 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
22:35:31 SimConnect: Event Received: SIM, 0
22:35:31 SimConnect: Event Received: PAUSE, 1
22:35:33 WinSock: Connected To localhost On Port 27015!
22:35:33 LUA Processor: Started!
22:35:33 Aircraft Connection Started
22:35:33 Simconnect Version: 4.0.0.0
22:35:33 Aircraft FullName: PMDG 737-800NGX WL
22:36:13 SimConnect: Event Received: SIMSTART, 0
22:36:13 SimConnect: Event Received: SIM, 1
22:36:20 Synchronising Switches & Selectors Complete
22:36:48 SimConnect: Event Received: INTERFACE_RESTART, 0
22:36:48 SimConnect Message Processing Finished
22:36:48 GoFlight Connection Starting.....
22:36:49 SimConnect Connection Starting.....
22:36:49 GoFlight Connection Started
22:36:50 SimConnect Message Processing Started
22:36:50 SimConnect Connection Started
22:36:50 Aircraft Connection Starting.....
22:36:50 PMDG SDK option is OK in Prepar3D v4
22:36:50 SimConnect: Event Received: Aircraft Type Changed
22:36:50 SimConnect: Event Received: SIM, 1
22:36:50 SimConnect: Event Received: PAUSE, 0
22:36:50 SimConnect Message Processing Finished
22:36:50 GoFlight Connection Starting.....
22:36:51 SimConnect Connection Starting.....
22:36:51 Creating Bespoke Vars
22:36:51 Bespoke Vars Created
22:36:51 Importing Bespoke Variables
22:36:51 Bespoke Vars Assigned, Importing Bespoke Events
22:36:51 Bespoke Events Temp Imported
22:36:51 Bespoke Events Imported
22:36:51 GoFlight Connection Started
22:36:52 SimConnect Message Processing Started
22:36:52 SimConnect Connection Started
22:36:52 Aircraft Connection Starting.....
22:36:52 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
22:36:52 SimConnect: Event Received: SIM, 1
22:36:52 SimConnect: Event Received: PAUSE, 0
22:36:54 WinSock: Connected To localhost On Port 27015!
22:36:54 LUA Processor: Started!
22:36:54 Aircraft Connection Started
22:36:54 Simconnect Version: 4.0.0.0
22:36:54 Aircraft FullName: PMDG 737-800NGX WL
22:36:54 Synchronising Switches & Selectors .....
22:36:59 Synchronising Switches & Selectors Complete
