QW 787
2»
  • Has the new QW 787 SP3 update changed anything with the MCP? I am currently holding back on the update incase the MCP does not work with SP3.
    When I try to import un GIT, I have immediatly GIT closed with an error.
    I dod not have any error with the first version.
    YVes
    YVes
    Which version of QW are you using?
  • at this time 1.3
  • @yvesamuel
    Please test this version v.0.2
    No changes really on the MCP.
  • Now it works, just a lttle problem with the speed indicator : -9999. is always indicated.
    Could I make one more request : the efis would be nice also.
    Thank's for your work
    Yves
    Yves
    Yves,
    As you can see on the release notes, I'm still stuggling with the speed display.
    I dont have an EFIS, so I can't program that one.
    Please let me know if you find other things which are not on the release notes.
    avelaz
  • avelaz, thanks so far for what your trying to achieve with the QW, keep up the good work
  • Here's version 1.0 with the MACH/IAS display solved and the LOC and APP light working.
    Let me know if you find any other issue to check it.
    Enjoy!
    P.S. @admin_pps Fell free to post it on the downloads if you want.
  • Can you provide your name, so I can give you credit.
    Avelaz is fine.... from MX =)
