Bendex KAP 140 (in MV 310R) ... anyone?
Has anyone done the Bendex KAP 140 (in my use case it's the MV 310R with GTN750/650/WX)? I'm having a heck of a time trying to get HDG and NAV working correctly. For HDG/ROL I'm seeing the two Lvars being sent and some EVENTS, but when I use the same Lvars and events I see the display in KAP 140 change to HDR or ROL but the aircraft will not respond. However, if I set a Lvars that is NOT related, used for NAV ARM then the HDG/ROL works as expected but it triggers the NAV Arm which is not really what I want ... I should be able to set HDG or ROL without NAV Arm.
I have most of the other aspects of the KAP140 working, Alt sel, Baro (this was a little tricky as it's based on current alt rounded up to nearest 100ft), Arm, Alt, AP, NAV (haven't done APR or REV yet as I need to have aircraft flight setup for that usage).
There are some Lvars reference to the KAP140_LuaNavKeyUp and a few other Lua ... I have really ever done much with Lua so trying to avoid that for now but will tackle it if necessary.
So if anyone has done the KAP140 and has some insight, please let me know. I'm missing something but there aren't that many KAP140 Lvars and not that many related events (gone thru them all).
