Want to use Rotation knob for cycling through functions
I have a GF-45 with two knobs with are working fine at the moment with GIT.
What i don't get work is using one of the rotation knobs to cycle through functions like HDG, ALT, Baro etc etc. At the moment i have this function programmed with a combination of GF-P8, so using a button to cycle through the functions.
Any idea to program this with bespoke events or other solution?
Thanks!
  • I'm not certain it can be done. You could try assigning the GF45_KEY_DEVICE event to the rotary.
    Sorry for the late reply. Thanks, i thought that i tried to use that already but not sure. Will try it again and share it when it is working.
    Kind regards,
    Andre
  • Tested and is working!
    I assigned the first rotary on the GF45 to GF_KEY_DEVICE. I can now cycle through functions but only One Way. What do i need to do for going backwards through the functions? So left rotation back, right rotation forward..
    Thanks again
  • There is no facility for that, it only goes one way. I will have to add that functionality to GIT in the next release.
