Strange behavior in NGX using the VS thumbwheel on the MCP Pro
I recently upgrade to the latest GIT and GF Config versions. Flying the last two days, I noticed some strange behavior. After beginning a descent, the VS thumbwheel worked correctly initially, rotate down for increased descent rate, rotate up to decrease descent rate. However, if once the vertical descent rate was set to greater than 1000 FPM, rotating the thumbwheel either up or down only increased descent rate. Some pretty high descent rates were generated. When I panned over to watch the thumbwheel in the simulator, moving the MCP Pro's thumbwheel either up or down only showed the thumbwheel moving down (increased descent rate).
Any idea what might be going on and/or how to fix it?
Thanks!
Rich Boll
PS. I'm getting a " Code 403 Community Garden Manage" error message when I typed this discussion item. In the Full Screen mode for Tablets, I could clear the error message and continue typing. From the first screen, I could not clear the message. FYI.. Thanks,
Thanks!
Rich Boll
