Trim Wheel Speed
If this has been answered, I sincerely apologize. I have searched the forums but couldn't find anything.
Is there a way to adjust the speed or ratio on the LGT trim wheel? I'm sitting in the C172 and it seems to take forever to get the trim set to where it needs to be. Any help is appreciated. Let me know if you need more information as I'm quite new to using GFIT.
Alternatively, if the aircraft is Simconnect compliant for the trim wheel, you could disable the LGT in GIT and enable in GFConfig so you are using GoFlights drivers which may perform better.
