SSL/TSL Secure Channel
Noticed this exception appearing in the logs the last couple of days.
08:47:47 GoFlight Connection Starting.....
08:47:47 X-Plane Connection Starting.....
08:47:47 Update Check Error Code: 0 - Exception: The request was aborted: Could not create SSL/TLS secure channel.
08:47:48 GoFlight Connection Started
08:47:48 X-Plane Connection Started
08:47:48 Aircraft Connection Starting.....
08:47:48 X-Plane: Event Received: Aircraft Loaded/Flight Loaded
08:47:50 WinSock: Connected To localhost On Port 27015!
08:47:50 LUA Processor: Started!
08:47:50 Aircraft Connection Started
Doesn't appear to have any effect on the GIT operation of the hardware.
Can you please advise?
Thanks.
  • Its the updated version check. Its failing because the ISP upgraded their security protocols and TLS 1.0 no longer works. Its been fixed ready for the next release.
  • Thanks Steve for the prompt reply.
