Request for supporting EVENTS via numeric value in LUA scripts
Is there any chance you might be able to add support so that we can send events to P3D via their numeric reference number, in addition to their text name?
The reason I would like to see this added, is that, with that additional functionality, I believe I can provide a mechanism by which P3D & FSX users will be able to very quickly and easily assign functions to their GF modules, without having to detect, generate or write code in GIT from many popular P3D/FSX aircraft.
Also, if you were able to provide additional function call names for the existing LUA commands writeLvar and readLvar, so alternatively they could be called using the function names of ipc.writeLVar and ipc.readLVar, it would mean even faster/quicker implementation of existing resources that could be used to assist programming GF devices in GIT.
I can provide details on how I believe this can reduce coding/dev time for aircraft modules in GIT and provide examples.
