Minor issues above my head
This is for Steve. When the beta interface came out you came into my computer and set it up . I just got a brand new rig built , I bought the interface tool and got the go flight conf. tool last week . I have 9 Go flight modules and when I bought the interface tool last week for some reason every thing that was set for some reason set itself in the interface tool like i had before witch is good cause I don't have to reprogram them . The issue is it has some minor issues and there's no way I can figure it out. Can you come in again with team view to stream line the set up and I'll pay you like last time ? remember your about 7 to 8 hours ahead ----Thanks Louis
What are the issues?
Brand new computer
Have these drives -- Local Disc (C) -- FSX (E) -- Mass(F)
Mass(F) is the complete back up of my old computer
I bought the Interface tool and downloaded the Go Flight conf.tool last week
The payware Interface tool some how imported all the PMDG settings from the Beta PMDG interface tool to this payware one the settings you assigned way back
In the Go-Flight Confi. i have
DEfaultFSX.gfc
General Aircraft.gfc
When you set me up you added PMDG to it - when i wanted to fly a PMDG i would go in the Go flight Conf. open PMDG and the beta interface pick a 737 and away we we'd go
Now flying general aircraft is fine, but when i open the Interface Pay ware and fly the PMDG they seem to be crossed with the general settings especially the Advanced Auto pilot . Don't know if i explained it right but flying the 737 is not like it was
1) Start GFConfig.
1a) If you own an MCP PRO, click on its picture and then click the drop down list box and set it to "Compatible Add-On" (it normally shows FS Default).
1b) If you own an EFIS, click on its picture and then click the drop down list box and set it to "Compatiable Add-On".
1c) If you own an MCP Advanced, click on its picture and ensure that all options are set to FS Default and all actions are set to nothing.
1d) Remove all assignments to all other devices in GFConfig that you wish to control via the GoFlight Interface Tool.
1e) In GFConfig, click File, Save Configuration As, and enter GIT or PMDG and then click Save. You must always load this configuration (if it isn't already loaded) before using the GoFlight Interface Tool.
Check in GFConfig that you have nothing configured for the GF46 in the PMDG config you made from my previous response. I suspect GIT and the GoFlight drivers are both writing to the GF46 and messing things up.
Not necessarily, your new PMDG profile will probably work fine with the 777.
