Some lights not working?
Suggestions please. I have worked countless hours on my goflight modules. Here is where I am at after latest download of my GIT for Xplane11.Original download was on 1/20/2017. I have 7 units total. SECM,GF-45,GF-TPM,GF-P8, all seem to work ok. Problems are as follow: 1. GF-LGT 2 has no gear lights and gear selector lever does not work, flaps lever does work.2. GF-ATC does not work at all, I do realize it currently is not supported. 3. GF-166a number display lights do not work although Ident works on the two green lights, but it does change the freq on aircraft panel. * at one time these all worked with exception of GF-ATC. Appeared to run into problems after downloading LATEST GIT?...Is it a must that I download a config file and download to GIF? I only want the default C172 to fuction at this time. It must something simple I am MISSING? **BTW, all modules work correct in P3d althought I only use the GF interface. All suggestions greatly appreciated! Roger
  • Hi Roger,
    Can you zip up Documents\GoFlight Interface Tool and attach the resulting file to this thread so I can check everything is as it should be.
  • Thanks for Reply Steve..Hate to say it..but not familiar with zip up a file..Document page will be in GIT file correct? Sorry..
  • Using windows explorer, right click on the directory and hover over "Send to" and then select Compressed (zipped) folder. This will create a zip file with the same name as the directory.
