Unable to get the SendKey or SendKey* to work with Ctrl + F11 sequence.
P3D V5.3, this used to work in V5.2.x so not sure why it isn't working now. I have HiFi ASP3D setup for Ctrl+F11, works fine when triggered manually in P3D but not via Detective. Any suggestions?
Cheers, Rob.
Cheers, Rob.
Not sure, the code hasn't been touched in years. I'll do a test my end and come back to you.
Cheers, Rob.
I'll clarify, when using iFly or PMDG, there is no "detective" (blocked) and hence no way to create bespokes for Sendkey Ctrl+F11 that I can assigned to a P8 button. I'd have to install Goflight's provided GFConfig and setup the Ctrl+F11 sequence there ... I'm trying to avoid installing GoFlights provided software.
Cheers, Rob.
