FENIX A320 GOFLIGHT
Any one made a config for FENIX A320
My FCU isnt working especially altitudes etc
  • Hello i'm at work on the fenix a320 for git, i have found everything to send event to fenix but nothing to get value to display, i put a first version asap
  • A first alpha, with partial mcp and efis support, no display but fd
  • A second alpha, with partial mcp and efis support, no display but all led
  • The first beta with mcp and left efis, no display but all led
  • Thanks for doing this, above my level these days to programme this.
  • And now the beta 2 with full support of mcp and left efis, but display
  • Hello, as long as Fenix did not provide a solution for the display indications I'm using the MCPPro displays as follows (better than blank or zeros indicated):
    IAS Display - Light / Display Data: AIRSPEED_INDICATED / Light Action: NOTHING / VALUE: 0
    HEADING Display - Light / Display Data: PLANE_HEADING_DEGREE_MAGNETIC / Light Action: NOTHING / VALUE: 0
    ALTITUDE Display - Light / Display Data: PLANE_ALTITUDE / Light Action: NOTHING / VALUE: 0
    V/S Display - Light / Display Data: VERTICAL_SPEED / Light Action: MULTIPLAY AS DECIMAL / VALUE: 66
    Now the MCP is showing actual values insted of commanded, espeacially the V/S Value needs to be refined, have with the calculated 66 the nearest to actual in ft/min. If someone has a more elegant solution, I would apprechiate it. Best regards Ralf
  • Is FSUIPC necessary . God knows what’s wrong . My configs used to work just fine for fenix . Tried importing these new configs also . MCP lights up but no button is moving . Only thing skipped was not auto loading FSUIPC .
    What else can be wrong
  • Hello no need of fsuipc, we are in contact with fenix but prosim the partner of fenixsim don't allow for the moment use of external hardware and not provide lvars necessary to do this
  • Thank you for making the zip file, but where to put it? I'm using MSFS 2020 via steam and so many places I can imagine to put this file. I get 3 green lights in GIT and can succesfully install your zip, but I suspect my location isn't correct since I can't use either GoFlight MCP pro or EFIS with fenix a320.
    Any help will be really appreciated. Bought FSUIPC and this GIT to make it work :)
