FS2020 GIT installation
I have the STEAM version of FS2020. Where do I install the Goflight GIT application?
What is wrong?
The GIT is running in the background. Use task manager to find GIT and right click on it and select End Task.
PS The GIT Module goes into your FS2020 Community folder.
I am unable to open the GIT app - get a message saying "An instance of the goflight interface is arleady running".
Do I open FS2020, then GIT or vice versa?
Also recommend you read the full manual here, especially the beginner guide: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git.html
How do I locate and download the ASOBO aircraft files to use with GIT?
The file is in LUA folder. What is the process for downloading these files for different aircraft from you site?
I have no modules configured currently. If I import a config it tries to load King_Air350.zip file ??
Yes, you do need to select the aircraft in FS2020 so GIT knows what aircraft you are configuring.
Where are you getting the zip file from as its not listed on our website?
