I need Again Help with GIT MSFS2020
Hello everyone,
I need the Brain power of the Community.......
,after a new instal of MS2020 and Git, i have NO SimmConnect.
When i start Git the FS Freeze an the SimmConnect light is yellow.
And i have a similar Problem with a other Software from CockpitMaster that uses also SimmConnect.
I have trie to install the FS SDK in Dev Mode, but there is still no connect.
Thanks the help
Florian
Thanks the help
Florian
After i give the FlightSimIOLua.exe Adminrights i have three greens
07:59:46 Bespoke Events Imported
07:59:47 SimConnect Message Processing Started
07:59:47 Synchronising Switches & Selectors: Waiting for SimConnect .....
07:59:47 SimConnect Connection Started
07:59:47 Aircraft Connection Starting.....
07:59:47 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
07:59:47 SimConnect: Event Received: SIM, 1
07:59:47 SimConnect: Event Received: PAUSE, 0
07:59:48 WinSock: Connected To 127.0.0.1 On Port 27016!
07:59:48 LUA Processor: Started!
07:59:49 Send Control Data: Too Many Retries
07:59:50 Send Control Data: Too Many Retries
07:59:51 Send Control Data: Too Many Retries
07:59:53 Send Control Data: Too Many Retries
07:59:54 Send Control Data: Too Many Retries
07:59:55 Send Control Data: Too Many Retries
07:59:56 GoFlight Connection Started
07:59:56 Aircraft Connection Started
07:59:56 Simconnect Version: 11.0.62651.3
07:59:56 Aircraft FullName: PMDG 737-700BBJ
07:59:58 Synchronising Switches & Selectors Complete
Do the errors continue? Does GIT work after "Synchronising Switches & Selectors Complete"?
Not realy, I have also a problem with P3Dv5 the Interface DLL is not loaded with the Sim.
In MSFS 2020 all works now, exept the XPNR that comes not on.
