Git P3d 64 bit freezes Mcp pro
It was working fine. All of a sudden it stopped working. Any ideas?. I reinstalled. Changed USB ports, read Many of the trheads un the fórum. The status tan says mcppro:1. But the mcppro tab it's not accesible . Can't get to the log tab it freezes.
P3D v5 pmdg 737 ngxu Windows 10 64 bits.
Any help would ve appreciated.
  • I can get it to work only with cfconfig.exe with default aircraft bit nota with pmdg 737.
  • What has changed on your system? Have you tried reinstalling GIT?
  • Hi, I did nothing. It just stopped working. I tried reinstalling everything, but no luck with git. It works with cfconfig.exe with default aircraft IN p3dv5, but when I open Git it freezes. By the way didn't find new drivers for cfconfig on the web page, so I'm using the old one i got. It happens with P3DV5 and MSFS2020.
    Thanks for your response.
    Javi
  • I think I'm going to reinstall everything. Windows, p3d and all. Is there a place where I can get the cfconfig.exe installer?. I still need that besides GIT wright?
    Regards.
    Javi.
  • Can you post your GIT Log from the Log tab.
  • Git freezes when i open it. I cant press anything. I found the cfconfig.exe installer, I'll do a fresh install of everything when I get home and I'll keep you posted.
    Thanks.
  • Try the 32bit version of GIT and let me know if the same thing happens.
  • Same thing with 32 bit. The thing Is for the mcp to work I have to manually open gfdevp3dv4.exe from the goflight folder. When I try to do that with pmdg 737 GIT freezes. In both cases there's no MCPPRO Tab.
    Sorry about the quality of the pictures. I hope this helps You help me. 😞
    I reality appreciate your Time.
  • Managed to hit log before it froze.
    Again sorry for the quality.
  • edited January 2023
    It looks like your BespokeVariables.xml file is corrupt. Replace it with a backup or simply delete it.
    Note if you delete it, and have bespoke var names changes in it, your configs and any imported aircraft configs may stop working as expected.
  • This may be a dumb question, but where do I find the BespokeVariables.xml?
  • Documents\GoFlight Interface Tool
  • I really appreciated the time you took to help me, i did delete the BespokeVariables.xml but same problem, what did the trick was replace de pmdg backup. And now it works.
    Regards.
    Javi
