Problems with GIT / FS2020 / PMDG 737 and GoFlight MCP PRO
Hi folks,
I have a few problems with my goflight MCPPro using FS2020 and PMDB 737-900:
1) Both COURSE rotaries are not working properly, the just jump in one direction when rotating. All other rotaries work fine.
2) The 7-segment displays only show zeroes, not the numbers of the sim
3) none of the button LEDs are working
Hope someone can help me.
Thank you very much for saving my day and sorry for my bad english ;-)
2) & 3) are related. Make sure in the GIT log you see PMDG SDK is OK. If ok, check the FAQ entry titled "My MCP PRO or MCP Advanced is not updating its display (just showing zeroes or dashes)" here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/41-faq/70-faq.html
If you still have issues with 2) & 3), post your GIT Log into this thread.
thank you for the fast reply.
You were right about the rotaries, check program had the same issue. I'll replace them
Tried to solve the problem with the displays and leds as described. No effect.
I looked after the pmdg SDK, but could not find it in my pmdg folders. Perhaps thats the problem. How can I install the PMDG SDK? There is no seperate download.....
Here is my log file:
17:16:24 GoFlight Connection Starting.....
17:16:24 SimConnect Connection Starting.....
17:16:25 GoFlight Connection Started
17:16:25 SimConnect Message Processing Started
17:16:26 SimConnect Connection Started
17:16:26 Aircraft Connection Starting.....
17:16:26 SimConnect: Event Received: Aircraft Type Changed
17:16:26 SimConnect: Event Received: SIM, 1
17:16:26 SimConnect: Event Received: PAUSE, 0
17:16:26 SimConnect: Event Received: VIEW, 2
17:16:26 GoFlight Connection Starting.....
17:16:26 SimConnect Message Processing Finished
17:16:26 SimConnect Connection Starting.....
17:16:27 Creating Bespoke Vars
17:16:27 Bespoke Vars Created
17:16:27 Importing Bespoke Variables
17:16:27 Bespoke Vars Assigned, Importing Bespoke Events
17:16:27 Bespoke Events Temp Imported
17:16:27 Bespoke Events Imported
17:16:27 SimConnect Message Processing Started
17:16:27 GoFlight Connection Started
17:16:27 SimConnect Connection Started
17:16:27 Aircraft Connection Starting.....
17:16:27 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
17:16:27 SimConnect: Event Received: SIM, 1
17:16:27 SimConnect: Event Received: PAUSE, 0
17:16:27 SimConnect: Event Received: VIEW, 2
17:16:29 WinSock: Connected To localhost On Port 27016!
17:16:29 LUA Processor: Started!
17:16:29 Aircraft Connection Started
17:16:29 Simconnect Version: 11.0.62651.3
17:16:29 Aircraft FullName: PMDG 737-900ER
17:16:29 Synchronising Switches & Selectors .....
17:17:00 Global LUA Event Running
17:17:00 Global Aircraft LUA Event Running
17:17:00 Synchronising Switches & Selectors Complete
Nothing about PMDG SDK okay....
To enable the data communication output, you will need to open the file
737_Options.ini that is located in the 737 persistent storage folder.
For Microsoft Store distribution, this folder is located at
%LOCALAPPDATA%\Packages\Microsoft.FlightSimulator_8wekyb3d8bbwe\Lo
calState\packages\pmdg-aircraft-737\work\.
For Steam distribution, this folder is located at
%APPDATA%\Microsoft Flight Simulator\Packages\pmdg-aircraft737\work\.
Once this folder is open, add the following lines as required to the bottom of
the file:
[SDK]
EnableDataBroadcast=1
Try again, if still no good, check the above again and see if it has been turned off.
PS it will pmdg-aircraft-739 and not pmdg-aircraft-737
I Added the two lines and it works!!!
Thank you very much for your help!!
Have a nice week!
Best wishes,
Stefan
