GIT for MSFS OK but now GIT for Xplane NOK
Hello Steves
since I installed GIT for MSFS on :C,
GIT for Xplane on : C does not work anymore and I have these messages :
thanks for your help
Roland
Roland
This will not erase any aircraft configs.
I don't have a GIT folder in the path you indicate
here is where all the GIT folders are if I haven't forgotten any....
thanks
the path is the right one see photo
the pluggin is ok in folder > plugin off Xplane
ok i change localhost by by adress IP
I precise you that before installing GIT for MSFS everything was ok for Xplane
thanks
Roland
The plugin needs to be enabled, not off.
Lua Config.txt is always replaced for every GIT install. Have you have updated the ip address in the file and its still not working?
now it works and for that I have to start GIT before starting Xplane the other way around doesn't work anymore.
I always have this message in first see photo is there a new version of GIT for Xplane or is it because I have GIT for MSFS that I have this message?
thanks
Can I download this new version via my account?
or do I have to buy it in your store?
once downloaded I delete the old one before installing it?
thank you for your answers
Roland
Not necessary to uninstall.
a big thanks Steve
best regards
Roland
I still haven't installed this new version.
Can you tell me how to do this?
Everything works fine and I don't want to make a mistake.
thanks a lot
Roland
Install instructions: https://www.pollypotsoftware.org.uk/support/user-guide/goflight-interface-tool-x-plane/33-installation/78-installation.html
and
if a member has already done this update can he tell me the steps
thanks a lot
i have two licences Xplane and MSFS
Roland
