GF46 does not display the DME
I installed all my Goflight modules on a new computer. I have them all working well (MSFS 2020, Windows 11, PMDG 737 800) with the exception of the DME display. When I set either Nav 1 or Nav 2, the DME shows up correctly on the PMDG MCP, but not on the Goflight GF46. It just shows up as Zero. In the 46R Option 1 button, I have it set as Clockwise, NAV1_STBY_SET, Rotary action Rotate, In the option 2 button, I have the same except that it is NAV2_STBY_SET. The third OPTION Button is Clockwise, DME, rotary action = Rotate, and the 4th option button is also clockwise DME Rotary action = rotate. If some can guide me through the correction so that the GF46 DME displays correctly I would greatly appreciate it. Thanks
Rob
  • What do you have in the 46O tab as you need a variable in there for anything to display?
  • Hi Steve, Thanks for taking the time to respond, and for guiding me in the right direction, There was a problem with two of the settings in the 460 tab. I found the error, corrected it, and now all is fine. Thanks again for your help. Rob
