P3DV5 64 bIt GIT Interface Tool - Fails To Connect
Windows 10 P3DV5 64 Bit PMDG 737 and 777. Have been using this configuration for some time until today when the GIT Tool loaded and then hung up. I have not intentionally made any recent changes.
Without the Sim running it displays either two 'greys' or two 'reds'. the Go Flight indicator is 'Green'.
On starting P3D the tool locks up and has obviously crashed and frozen. I cannot determine if it is the GIT Tool or Simconnect?
I have installed the very latest version of the tool and re-installed Simconnect but the symptoms persist.
Any suggestions would be appreciated. TIA.
Not sure if this helps but herewith GIT Log File Contents with TQ6 connected but no sim:
17:19:31 GoFlight Connection Starting.....
17:19:31 SimConnect Connection Starting.....
17:19:32 GoFlight Connection Started
Green, Red Flashing and Red in that order
Empty Config file created
Three Greens
Sim Started; Green, Yellow, Green
PMDG 777 selected
Three Greens when a/c almost established, 777 recognised in Col 3
TQ6 Enabled
Default PMDG 737 selected
All throttle functions/buttons respond except; Reversers intiate reverse thrust but engines remain at idle. This can be achieved by pressing F2 key but previously on moving levers engines went to full revere thrust on lever movement alone. If this is the only remaining problem I can live with that.
Your assistance is greatly appreciated
Roger
It may be worth overwriting the new/empty config files with your backup files. This will restore all aircraft configs and your calibration for the TQ6. However if the backup files are corrupt you may end up with GIT locking up again.
Rgds - Roger
Thanks again Steve
Rgds - Roger
