GIT for MSFS OK but now GIT for Xplane NOK
Hello Steves
since I installed GIT for MSFS on :C,
GIT for Xplane on : C does not work anymore and I have these messages :
thanks for your help
Roland
  • edited May 2023
    It looks like your settings file is corrupt. Delete C:\Users\your username\AppData\Local\PollyPot_Software.
    This will not erase any aircraft configs.
  • Hello Steve ,
    I don't have a GIT folder in the path you indicate
    here is where all the GIT folders are if I haven't forgotten any....
    thanks
  • Just checked, the forum didn't post the full directory correctly because I added <> symbols. Updated it, so check again replacing "your username" as appropriate.
  • and this is the log GIT with Xplane 1205 and Zibo v3.55.ea_2_1 -
  • Check the plugin is present in X-Plane plugins. Also consider changing localhost in Lua Config.txt (in Documents\GoFlight Interface Tool) to be your IP address.
  • hello:
    the path is the right one see photo
    the pluggin is ok in folder > plugin off Xplane
    ok i change localhost by by adress IP
    I precise you that before installing GIT for MSFS everything was ok for Xplane
    thanks
    Roland
    sorry i fing the folder but the name is Pollypot_sofware and not GIT
  • Yes that is the right folder as stated.
    The plugin needs to be enabled, not off.
    Lua Config.txt is always replaced for every GIT install. Have you have updated the ip address in the file and its still not working?
  • everything you tell me is OK
    now it works and for that I have to start GIT before starting Xplane the other way around doesn't work anymore.
    I always have this message in first see photo is there a new version of GIT for Xplane or is it because I have GIT for MSFS that I have this message?
    thanks
  • Yes, there is a new version to download.
  • Hello Steve ,
    Can I download this new version via my account?
    or do I have to buy it in your store?
    once downloaded I delete the old one before installing it?
    thank you for your answers
    Roland
  • Your account always has the latest version, no need to buy it again.
    Not necessary to uninstall.
  • ok
    a big thanks Steve
    best regards
    Roland
    Hello Steeves,
    I still haven't installed this new version.
    Can you tell me how to do this?
    Everything works fine and I don't want to make a mistake.
    thanks a lot
    Roland
  • ok thanks Steeve , i try it
    and
    if a member has already done this update can he tell me the steps
    thanks a lot
    i have two licences Xplane and MSFS
    Roland
