MSFS 2024
GIT don't work with 2024. Will it be fixed to work?
your username\AppData\Local\Packages\Microsoft.Limitless_8wekyb3d8bbwe\LocalCache\Packages\Community. Started up FS2024 and then GIT and everything worked.If this doesn't work for you, please provide more info/logs etc.
I will get a new installer out over the weekend, unless other problems are found in the meantime.
