MSFS 2024
GIT don't work with 2024. Will it be fixed to work?
«1
  • Would like t know as well.
  • I'm downloading it now so can look at it tomorrow. I would expect the GoFlight Interface Module just needs copying to the new community folder - have you tried this?
  • I have just done a quick test and copied the directory "pollypotsoftware-flightsimio-module" from my FS2020 Community folder into C:\Users\your username\AppData\Local\Packages\Microsoft.Limitless_8wekyb3d8bbwe\LocalCache\Packages\Community. Started up FS2024 and then GIT and everything worked.
    If this doesn't work for you, please provide more info/logs etc.
    I will get a new installer out over the weekend, unless other problems are found in the meantime.
  • Yes this time it has worked :)
  • New version now out for MSFS. This is an initial release with further updates shortly.
  • Wonder what the definition of "Shortly" is here?
    But supposedly the current LVARS and Datarefs for FS2020 will work in FS2024.
    Will find out in a few hours when the PMDG 737-800 releases.
    I have just purchased and installed the PMDG 737-800 for MSFS2024. Loaded up and started the GIT. EFIS seems to work but the MCP doesn't.
  • I just tried adding
    [SDK]
    EnableDataBroadcast=1 to the options. ini files as I did in 2020 but this time it didn't work in 2024 is there a fix to get the Go-Flight MCP working?
    That was quick :dizzy:
  • Just tried this version. MCP still don't work.
    Same. Loaded the new version, but still no MCP. EFIS is fine.
  • I have taken a quick look and GIT won't recognise the name of the new aircraft. Its a fairly straight forward fix so I will get an update out over the weekend.
    Thanks Steve, fingers crossed there are no hidden issues....having worked in IT myself I know what it can be like...
  • Over a week now still waiting for that fix ......... :disappointed:
  • Any news on this update? Really missing having the hardware available.
  • for Mr ipearse this thread is well over a year old. My Go-Flight MCP works after the recent update this week.
  • What version of the software are you running?
  • For MSFS 2024 4.8.1.0
  • That is the version I have. I have the flightsimio module installed in the Community folder. When I fire up MSFS2024 and load in the 737, then start the GIT, I get all greens on the tool, the EFIS responds, but the MCP is still not responding.
  • The Status tab correctly identifies the aircraft as the PMDG 737-800...
  • The Status also shows the MCPPRO and EFIS both connected.
  • Have you added [SDK] EnableDAtaBraodcast=1 into the 737 ini folder?
  • If you have not done that, the mcp won't work the dials in the sim. Google [SDK] EnableDAtaBraodcast=1
  • Added that, but still no joy.
  • re-read the installation instructions and checked USB connections. Made sure all USB 2.0 as specified. Still no joy.
  • Decided the problem was my old USB Hub. Got a new one, powered, USB 2.0. Still no joy. Now I'm completely stumped.
  • Does anyone know of a way to test the panel itself? When I unplug and replug the USB connection, the displays light up briefly and do their test count, then go blank again. Is there any other way of testing it?
  • This is what the status looks like - all looks good to me but the MCP still will not work - what am I missing?
  • I am about ready to consign this EFIS and MCP to the bin. I have tried everything that has been suggested, to no avail. Entries in the .ini files, check. USB2.0 ports directly on the PC backplate, check. Latest version of the GIT software, check. IOModule package in the Community folder, check. MCP and EFIS showing in the GIT Status tab, check. However, the EFIS only partly works, and the MCP doesn't do anything at all. When I power on my PC, the displays and LEDs on the MCP light up briefly, the displays do their count, then it goes dark, as expected. What am I missing? Could some other bit of software be interfering?
