MSFS 2024
GIT don't work with 2024. Will it be fixed to work?
  • Would like t know as well.
  • I'm downloading it now so can look at it tomorrow. I would expect the GoFlight Interface Module just needs copying to the new community folder - have you tried this?
  • I have just done a quick test and copied the directory "pollypotsoftware-flightsimio-module" from my FS2020 Community folder into C:\Users\your username\AppData\Local\Packages\Microsoft.Limitless_8wekyb3d8bbwe\LocalCache\Packages\Community. Started up FS2024 and then GIT and everything worked.
    If this doesn't work for you, please provide more info/logs etc.
    I will get a new installer out over the weekend, unless other problems are found in the meantime.
  • Yes this time it has worked :)
  • New version now out for MSFS. This is an initial release with further updates shortly.
