EFIS Module - can it be enabled for all aircraft?
I have the GoFlight MCP Pro and EFIS units. Whilst I can freely assign actions to the MCP Pro irrespective of aircraft I can’t do the same for the EFIS. It’s disabled unless the aircraft is a 737/777.
I want to utilise the Baro knob and dial for assigning barometric pressure adjustments. Any chance you can enable it please for all aircraft?
Ray (Cheshire, England)
I have created three Bespoke Events - BaroInc, BaroDec and BaroToggle.
The first two use the Kohlsmann Inc and Dec commands. The push button for the Baro knob toggles between hPa and Inches. I've watched Rob's video to learn how to use If Else commands. My code for that toggle is attached. Can you confirm that's how you would code it? It appears to work okay. A slightly wider window for that code would be helpful.
OK, maybe it's on their list or not - in meantime do you have a workaround for this (except that I have to write a LUA script - unfortunately I got not a single LUA script to run in the past). Some bespokes for Baro and DH INC/DEC would be nice, could not do it for my own, since GIT inspector is blocked for PMDG's Best regards Ralf
I'll take a quick look, but I'm not hopeful as GIT is sending the events to turn the EFIS rotary and its not working - in the past, this was always because the rotary option needed to be set in the FMC. Perhaps different mouse options with the event may work - I'll test it tomorrow.
Sorry to return to this topic but I'm trying to program the Baro knob on the EFIS for FS Labs Concorde.
Using Detective I've successfully created two Events - Baro_Inc and Baro_Dec. They both work when the "Test Bespoke Event" is actioned.
But on the EFIS tab despite the Device being ENABLED the Function option remains "DISABLED".
Any way to get it enabled so I can assign these two events please?
Here's the screenshot showing the EFIS Function option shows Disabled. Whilst I've assigned an Event to Clockwise and AntiClockwise actions the baro reading does not change when the knob is rotated.
I'm wondering if Concorde using a custom autopilot might be the reason. The Lear25 uses the default P3D autopilot.
