MCPPRO / EFIS no longer works with the latest XPLANE12 update
Hello, since the last update of Xplane 12 and with the 737 ZIBO, I have just noticed that my EFIS no longer works at all and that on the MCPPRO only the IAS/MACH wheel no longer works. Does anyone have a solution? Thanks in advance
I'm very happy to hear from you, but I can't download the profile. My command appears correctly, but I can't download GIT XPlane.zip. Could you tell me how I can download it? Thanks for your reply
I've done this several times by downloading the ZIBO profile, and the problem persists on my EFIS and MCPPRO, however, I can no longer download the GIT software from the downloads. I would like to try uninstalling and installing the main software. What I don't understand is that this worked perfectly before the Xplane update. Thank you for your reply.
I do sometimes lose bindings through GIT, but then I just import the profile again, and all is back to normal.
And YES I did export my EFIS, MCPPRO and GF166 profiles as a backup. Something I highly recommend.
Are you also running the Zibo mod in xplane12?
If so, what profile did you use to get the mcp pro to work?
I tried the xplane profile on the pollypot webite, but only a few on the mcp functions work for me.
Running xplane version 12.3.3.
