GF-SECM support for MSFS2024
The SECM interacts with MSFS2020 as expected. But I discover issues with MSFS2024. When loading the Asobo C172SP the interface tool seams to connect and most of the switches are working after a click to Default FS. Unfortunately fuel pump and avionic master switches trigger nothing. I unsuccessful played with different options. Therefore is there a know setting witch brings those two buttons to work?
With the RP48 I have no issues so far.
Thanks for help.
  • SECM: Meanwhile I managed to control the Asobo C172SP fuel pump switch via a key command. Unfortunately I could not find any MSFS2024 key command for the Aviation Master Power switch. All commands I tested had no effect and detective detects a strange event.
    Any hint how to fix this last switch?
