NAV Radio control on PMDG777 in P3Dv5
Hi Steve. When flying the PMDG777 their software appears to have control of the NAV 1/2 radios. I cannot change a frequency using the GF166.
Is there any way around this? The PMDG737 Nav radios are fine.
Ray (Cheshire, England)
  • Have you tried clicking the NAV button on the GF166 tab with the 777 loaded? I recall that PMDG aircraft worked with the standard Simconnect events.
  • Hi Steve. No, I haven’t but will try and report back.
  • Hi Steve, When I did that a warning message appeared. Is this what you would expect? Will I lose anything that can't be restored?
  • Anything you have configured on the GF166 device selected will be changed but only for the 777. Make sure you have the GF166 device number you want to change selected.
  • All I have in PMDG.xml for the 777 are some T8 and P8 actions. The 166 section is clear.
    Can I also perform the same thing for the COM radios. At present I need to click a button on the COM section in the 777 to get the 166 to work correctly.
  • Yes. The COM, NAV & ADF buttons configure the currently selected GF166 device to use standard Simconnect events and variables for the currently loaded aircraft. The GF166 configuration will be saved - you will only need to do it once, unless you want to change what the GF166 does.
  • Thanks Steve. Do I take it that doing this stops the PMDG logic automatically selecting the nearest VOR station plus the ILS frequency for the landing runway?
  • I don't think so. GIT will just send requests, the PMDG logic decides what to do with those requests.
  • Understood. I’ll suck it and see. Thanks Steve. 👍
