Basic general
Trying to get the Prop Synch to work,  works ok with the Go-flight module set up.
In the GIT, I can select the same Toggle Prop Sync and the light indication but it has no reaction. If I toggle the VC button the indicator comes on, there is only a toggle selection available as far as I can see (same as in GF config) no matter what unit button I define it to, it will not trigger the action.
I can define it in FSUIPC and it works ok as well.
Any suggestions please ?
Trevor
  • edited November -1
    Hi Trevor,
    Is the prop sync default FSX or an advanced aircraft using lvars, custom events?
    Hi Trevor,
    The Simconnect SDK had an error in it. It came with the event TOGGLE_PROP_SYNC, however the documentation states its TOGGLE_PROPELLER_SYNC.
    I have updated GIT and it now works OK. Wait for the next release, and remove TOGGLE_PROP_SYNC from your configuration.
    Ta Steve,
    Glad some of my problems help
    Hi Trevor,
    This issue is now fixed in 2.0.351.0.
