2.1.14.3 Yellow light on Simconnect
i have managed to get GoflightInterfaceTool to work with X-plane, now i cant get the FSX-Steam edition to connect properly.
i have 2 xml entris in fsx
one is dll the other is exe
the dll goes like this
<SimBase.Document Type="Launch" version="1,0">
<Descr>Launch</Descr>
<Filename>dll.xml</Filename>
<Disabled>False</Disabled>
<Launch.ManualLoad>False</Launch.ManualLoad>
<Launch.Addon>
<Name>Object Placement Tool</Name>
<Disabled>True</Disabled>
<ManualLoad>False</ManualLoad>
<Path>..\Microsoft Flight Simulator X SDK\SDK\Mission Creation Kit\object_placement.dll</Path>
</Launch.Addon>
<Launch.Addon>
<Name>Traffic Toolbox</Name>
<Path>..\Microsoft Flight Simulator X SDK\SDK\Environment Kit\Traffic Toolbox SDK\traffictoolbox.dll</Path>
</Launch.Addon>
<Launch.Addon>
<Name>Visual Effects Tool</Name>
<Path>..\Microsoft Flight Simulator X SDK\SDK\Environment Kit\Special Effects SDK\visualfxtool.dll</Path>
</Launch.Addon>
<Launch.Addon>
<Path>C:\Program Files (x86)\GoFlight\FSX-SE\GoFlight Interface Module.dll</Path>
</Launch.Addon>
</SimBase.Document>
and the exe
<Filename>EXE.xml</Filename>
<Launch.ManualLoad>True</Launch.ManualLoad>
<Launch.Addon>
<Name>Addon Application</Name>
<Path>C:\MyPath\Addon.exe</Path>
<CommandLine></CommandLine>
<NewConsole>True</NewConsole>
</Launch.Addon>
<Launch.Addon>
<Name>GoFlight Hardware Interface</Name>
<Path>C:\Program Files (x86)\GoFlight\GFDevFSX.exe</Path>
</Launch.Addon>
</SimBase.Document>
what am i doing wrong here
<Launch.Addon>
</Launch.Addon>
<Launch.Addon>
</Launch.Addon>
<Launch.Addon>
</Launch.Addon>
<Launch.Addon>
</Launch.Addon>
</SimBase.Document>
and the exe
<Launch.Addon>
</Launch.Addon>
<Launch.Addon>
</Launch.Addon>
</SimBase.Document>
23:36:05 GoFlight Connection Starting.....
23:36:05 SimConnect Connection Starting.....
23:36:06 GoFlight Connection Started
23:36:15 SimConnect Message Processing Started
23:36:15 SimConnect Connection Started
23:36:15 Aircraft Connection Starting.....
23:36:16 SimConnect: Event Received: Start
23:36:16 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
23:36:16 SimConnect: Event Received: SIM, 0
23:36:16 SimConnect: Event Received: PAUSE, 0
23:36:16 SimConnect: Exception Received: OUT_OF_BOUNDS
23:36:16 Aircraft Connection Started
23:36:16 Simconnect Version: 10.0.62613.0
23:36:16 Synchronising Switches & Selectors .....
23:36:16 Synchronising Switches & Selectors: Waiting for Simconnect .....
23:36:28 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
23:36:35 SimConnect: Event Received: Aircraft Type Changed
23:36:35 SimConnect Message Processing Finished
23:36:35 GoFlight Connection Starting.....
23:36:35 SimConnect Connection Starting.....
23:36:36 GoFlight Connection Started
23:36:36 SimConnect Message Processing Started
23:36:37 SimConnect Connection Started
23:36:37 Aircraft Connection Starting.....
23:36:37 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
23:36:37 SimConnect: Event Received: SIM, 0
23:36:37 SimConnect: Event Received: PAUSE, 1
23:36:38 Aircraft Connection Started
23:36:38 SimConnect: Exception Received: OUT_OF_BOUNDS
23:36:38 Simconnect Version: 10.0.62613.0
23:36:54 SimConnect: Event Received: SIMSTART, 0
23:36:54 SimConnect: Event Received: SIM, 1
23:36:54 SimConnect: Exception Received: OUT_OF_BOUNDS
23:36:55 SimConnect: Exception Received: OUT_OF_BOUNDS
23:36:56 SimConnect: Exception Received: OUT_OF_BOUNDS
23:36:57 SimConnect: Exception Received: OUT_OF_BOUNDS
23:36:58 SimConnect: Exception Received: OUT_OF_BOUNDS
23:36:59 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:00 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:01 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:02 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:03 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:04 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:05 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:06 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:07 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:08 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:09 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:10 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:11 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:12 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:13 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:14 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:15 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:16 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:17 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:18 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:19 SimConnect: Exception Received: OUT_OF_BOUNDS
23:37:21 Synchronising Switches & Selectors Complete
exe.xml seems fine as the GFDevp3d.exe starts up, GFT is using Simconnect 1.4.0.0, i have installed the Simconnect from the p3d folder and rebooted but im on the edge of giving up, i recently bought a complete Goflight Airline stack and really need this to work.
is there any way to get GFT to use an other version of Simconnect.
bytheway i use p3dv2 2.5.1.2946.0
maby p3dv2 isnt supported
frank
It's the GoFlight Interface Module.dll that is used in GIT, the other stuff is GoFlight software which GIT doesn't use. If you are seeing this in all versions I would rename My Documents\GoFlight Interface Tool to eliminate any corrupt files.
I'm also concerned about this line:
All GIT software should be installed in C:\Program Files (x86)\GoFlight\ and not a subdirectory of it which you have used (FSX-SE)
Did you get a prompt when running flight sim about the GoFlight Interface Module loading?
this is my exe.dll in p3d, and im not getting a warning when starting the game
<?xml version="1.0" encoding="Windows-1252" ?>
<Launch.Addon>
<Name>GoFlight P3D Data Bridge</Name>
<Path>C:\Program Files (x86)\GoFlight\GFDevP3D.exe</Path>
</Launch.Addon>
</SimBase.Document>
this is my exe.dll in p3dv2.5
frank
<Launch.Addon>
<Name>FSUIPC 4</Name>
<Path>Modules\FSUIPC4.dll</Path>
</Launch.Addon>
<Launch.Addon>
<Path>C:\Program Files (x86)\GoFlight\GoFlight Interface Module.dll</Path>
</Launch.Addon>
</SimBase.Document>
it seems that i got it working, dll.xml instead of exe.dll,
ps! check out our 70-80s inspired neo/progrockband TerraMater on facebook :-)
