Small error With GF166 /Default FSX COM1&2 setting
When I use the button to set default COM1&2 with the GF 166's they work ok except that it always sets the left and right displays as "divide_by_decimal" and 100 in the light value box the light display data section.
I have to go through each new aircraft and change the setting to none otherwise 128.30 would be displayed as 1.28. Not sure if it's just a typo in the default setting? All of the default aircraft I tried in P3DV3 didn't need divide_by_decimal
  • It might be there from when it was originally developed for FSX. I'll test against all versions of flight sim and come back to you.
  • Fixed in 2.1.18.4 that I'm uploading now.
