GIT Crash with WIN10 and P3D V3.1
Hi Guys,
Yesterday i have Update my Computer to WIN10 and my Simulator to P3D V3.1.
After i installed FSUPC, all the Simconnect.exe in the redist folder and the SDK , i have installed the latest Version of the Goflight Config Setup 2.2.6.1.
After the installation i Installed the new Version of GIT in the Same folder and put the [SDK] EnableDataBroadcast=1 in the Pmdg737 Option.ini, then i checked de dll.xml for this linesm which where allready inside.
<Launch.Addon>
<Disabled>False</Disabled>
<Path>C:\Program Files (x86)\GoFlight\GoFlight Interface Module.dll</Path>
</Launch.Addon>
After that i started the GIT and than P3D, i choose the PMDG and that ist. The GIT Stop working it freeze nothing happend.
i Cant even click on the button Settings or Status. Only the Simconnect light is green and the other two are Red and freeze.
I hope you guys can helped me
Greetings from germany
Cemo
Its a known problem. You need to use this version of the GoFlight Drivers:
https://www.dropbox.com/s/txy23id0n7nqbck/GFConfigSetup_2_25_2.zip?dl=0
Try renaming My Documents\GoFlight Interface Tool.
Ok work through these threads:
http://www.pollypotsoftware.org.uk/vanillaforums/discussion/295/clean-win10-install-still-no-go-for-git-2-1-18-2-and-gf-2-26-1#latest
http://www.pollypotsoftware.org.uk/vanillaforums/discussion/271/gfit-lockup-at-start-after-install-new-go-flight/p1
