EADT x737 v5 MCPPro+EFIS
This is for the new EADT 737v5 , MCPPro+ captains EFIS
Enjoy
Edit: I'll try to get blanking working for the VS and IAS displays sometime but I gave up on that for now, it was too much code and the VC and hardware got out of sync
Works with Ver 1 as Ver 1.3 CTD's for me.
Trevor
Hi Trevor,
At what point does 1.3 crash?
Bex64
X-Plane.exe
10.4.5.3
56bcd7e2
SHLWAPI.DLL
a whole lot more numbers
OS ver 6.1.7601.2.1.0256.1
ver 1 works a treat no problems at all. have done a clean install of 1.3 and CTD overwrote with ver 1
no problem. Changed to default Baron made no difference.
Cheers
Trevor
Hi Trevor,
So its X-Plane that is crashing, not GIT? Does X-Plane with the GIT Plugin crash if GIT itself is not running with v1.3?
X-Plane crashes on load, only if the GIT plugin is in the folder and only the ver 1.3.
I never start Git until after X-Plane is running.
Does not matter which aircraft is been first to load either.
Tried a clean start up (Git with no entry's) still the same.
I did another download in case I had a faulty download but still the same.
Cheers
Trevor
Hi Trevor,
How strange. You don't have the IXEG or other Gizmo type plane loading as default?
Can you zip up your Documents\GoFlight Interface Tool directory and send it to me at info@pollypotsoftware.org.uk or attach it on this thread.
Steve.
PS: And load X-Plane with an inbuilt aircraft and see if it still crashes on startup. If it does, tell me which one you used so I can replicate your config.
I found this problem with new build of win 7, new build of X-Plane,
only default scenery no plugins and no extra aircraft.
I'll download fresh copy of 1.3 and remove plugins and try slayers suggestion with defender I have no anti virus on my flight machine.
btw .http://forums.x-plane.org/index.php?/forums/topic/102860-new-x-plane-interface/
about halfway down is another report by SWAQ4420.
Hi Trevor,
I have already spoken to SWAQ4420 and he is using Gizmo enabled aircraft and Gizmo is bugged. The Gizmo developer has acknowledged the fault with Gizmo (its not only GIT that is affected).
Let me have your config files please so I can resolve this.
Just checking to see if my email got thru to you with my files..
Cheers
Hi Trevor,
Yes thank you. I'm still working though possible issues. I'll come back to you sometime over the next few days.
Hi Trevor,
Can you replace the GIT Plugin with the one below. Replace in <xplane directory>\Resources\Plugins
https://www.dropbox.com/s/xarkpoh7kzqowky/GIT%20Plugin.zip?dl=0
Replaced, X-Plane started without a CTD.
Works like a charm.
Cheers
Trevor
Great news. Thx for letting me know.
What language is Windows configured to use?
I'll have to take another look at the language issue.
Hi TorstenD,
I have uploaded a new GIT for XPlane version. See if that helps with the import issue. Use the Import Wizard and make sure you delete all existing Bespoke Events via the Wizard.
