GIT for P3D
Hi
I get the GIT 1 week ago and installed it step by step, but unfortunately I haven't make it work.
Everything looks good all 3 lights are green but for some reason the tabs are not available, I read everywhere but I cant solve the problem. Probably I'm doing something wrong or missing something, but I don't know what it is.
I will appreciate some help..
Thx in advance Willieg
The tabs only become enabled when the virtual cockpit shows of an aircraft. The only other thing it may be is that the GoFlight Module is not installed/running - See the installation instructions for details on where this is installed and setup.
Have you checked that the module is being loaded in dll.xml?
The file C:\<accoutname>\AppData\Roaming\Lockheed Martin\Prepar3D\dll.xml must have the following entry in it:
The <Path> may be different depending upon where you installed GIT.
No. Everything is OK in the log.
Can you confirm you are loading up a flight and getting P3D into sim mode (virtual cockpit showing and flight loaded) as the tabs will stay disabled until you do that - you must have the sim in a flyable state.
OK. Let me know.
Make sure its the tabs that are greyed out - i.e. you cannot click on them. If you can click on them, then its OK and you should select a Device from the drop down for the fields to be enabled.
Make sure the path to the GoFlight Module is also correct and the right file has been updated - I suspect it isn't loading and this is causing the issue.
No its just kept the settings and remembered you have already agreed to it.
Check the FAQ entry "FSX/P3D/FSX SE Crashes on start up indicating an error with the Goflight Interface Module" and make sure those registry entries are correct.
Make sure you are running the P3D version of GIT and not the FSX or SE version.
Can you also attach your dll.xml file for me to check.
Let's arrange a remote desktop session to see if I can spot anything.
I think is a good idea,, I'm in MEXICO and work from Monday to friday, so can we organize for the weekend (Saturday or sunday) in the most suitable time for you. please let me know and we can do it .
thx a lot Steve, hope we can solve this issue, have a great day
** I add some pictures of my home cockpit,,, enjoy LoL!!!
Yes, that is fine. I will email you the details for Saturday.
