LeoBodnar BBI-32 & GIT 2.6.0.0 P3D version - issues/crash
I just received a BBI-32, as I had noticed earlier version ChangeLog mentioned you had added support for this card in GIT.
I plugged it in, and my system recognized the card.
I couldnt find any tab for the BBI-32, so I assumed that it might come under the 'Joystick' tab, which was greyed out as I have not enabled this option.
I went to the settings tab to enable Joysticks, and Save Settings.
I then quit GIT and relaunched it, when a warning advised me to save all my settings, and that it was
"Unable to Load Bespoke Events:Index was outside the bounds of the array"
Haven taken a backup, I clicked OK and GIT showed all tabs as greyed out.
Status tab showed it had recognized all of my GF hardware, but all tabs were greyed out, including the Joystick tab.
I clicked on the restart button in GIT, and got the same warning, but this time the Joystick tab was active (but all other GF tabs still greyed out).
I was able to see the BBI-32 card in the list of joystick deices, enabled it, saved a function to button 1, and then went to the Settings tab.
Just before I hit the save Settings button, I noticed the Enable Joystick checkbox was not ticked
I can only return GIT back to its normal working condition if I directly edit the Settings.xml file and set <JOYSTICKSENABLED Enabled/> to False
  • Hi David,
    Some joysticks crash GIT which is why the option is disabled by default. Can you remove the BBI-32 and then enable the joysticks option and see if GIT still crashes. If so we need to determine which Joystick device is causing the problem. The best way to do this is connecting the joystick devices one at a time. Once you have identified the offending device, copy and paste the GIT Log and attach it to this thread.
    thanks for the reply.
    I have removed all of the joystick devices that I could and tested after removal of each one.
    There is one remaining, that I am not able to remove, as its a virtual driver, and even in the hardware manager config page, I am not able to disable this virtual driver.
    I do actually depend on this virtual driver for this device.
    Anyway, the driver/virtual device is:
    3Dconnexion KMJ Emulator
    and allows the 3DConnexion device to appear as a joystick device.
    The GIT log contained this:
    18:10:51 GoFlight Connection Starting.....
    18:10:51 SimConnect Connection Starting.....
    18:10:52 SimConnect Message Processing Started
    18:10:52 GoFlight Connection Started
    18:10:52 SimConnect Connection Started
    18:10:52 Aircraft Connection Starting.....
    18:10:52 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    18:10:52 SimConnect: Event Received: SIM, 1
    18:10:52 SimConnect: Event Received: PAUSE, 0
    18:10:55 FSUIPC: Connected!
    18:10:55 Aircraft Connection Started
    18:10:55 Simconnect Version: 3.2.0.0
    18:10:55 Synchronising Switches & Selectors .....
    18:10:55 LvarNamesUpdated!
    18:10:55 Creating Bespoke Vars
    18:10:55 Bespoke Vars Created
    18:10:55 Importing Bespoke Variables
    18:10:55 Bespoke Vars Assigned, Importing Bespoke Events
    18:10:55 Bespoke Events Temp Imported
    18:10:55 Bespoke Events Imported
    18:10:55 Loading Aircraft Settings
    18:10:55 GetXMLConfigData
    18:10:55 GotXMLConfigData
    18:10:55 Loading Power
    18:10:55 FP Device Found: 3Dconnexion KMJ Emulator
    18:10:56 Device Found: Audio Controls
    18:10:56 Device Found: USB Keyboard
    18:10:56 Device Found: GoFlight GF-P8 control module
    18:10:56 Device Found: GoFlight GF-RP48
    18:10:56 Device Found: WCP
    18:10:56 Device Found: GoFlight GF-T8 control module
    18:10:56 Device Found: HID-compliant device
    18:10:56 Device Found: MESM
    18:10:56 Device Found: LGTII
    18:10:56 Device Found: GF-166
    18:10:56 Device Found: MCP PRO
    18:10:56 Device Found: GF EFIS
    18:10:56 Mouse Device Found: Mouse
    18:10:56 Keyboard Device Found: Keyboard
    18:10:56 Joystick Found Device 0: 3Dconnexion KMJ Emulator
    18:10:56 Device 0 Button Count: 4
    18:10:56 Device 0 POV Count:1
    18:10:56 Loading MCPPRO
    18:10:56 Loading EFIS
    18:10:56 Loading P8
    18:10:56 Loading T8
    18:10:56 Loading RP48
    18:10:56 Loading MESM
    18:10:56 Loading WP6
    18:10:56 Loading LGT
    18:10:56 Loading LGT II
    18:10:56 Loading GF46
    18:10:56 Loading GF45
    18:10:56 Loading TQ6
    18:10:56 Loading DIO
    18:10:56 Loading GF166
    18:10:56 Loading SECM
    18:10:56 Loading Joysticks
    18:11:07 SimConnect: Exception Received:  NAME_UNRECOGNIZED
    18:11:21 Synchronising Switches & Selectors Complete
    Hope this helps
  • edited December 2016
    Great, I'll build a test version for you that excludes that device. Since your email address is not listed in the Shop, I need you to PM me your Shop email address or login name and invoice number.
  • HI Steve,
    That worked - many thanks.
