GIT, IXEG 737 and Auto Throttle
I'm having an issue with GIT, using the auto throttle with the IXEG 737. When I arm the auto throttle, the throttles immediately increase to full power. After activating TOGA the engines reduce to take off thrust then once in the air one engine reduces to idle.
I have the latest GIT downloaded, the lastest new version of x-plane 11.
I have deleted all the current Bespoke events and updated them with the Import Wizard.
This error does not occur if I arm the auto throttle clicking the mouse on the switch, but only arming the a/t using the Go-Flight MCP-Pro.
Any thoughts welcome.
Cheers
Graham McAllister
Feel free to open the detective and look at the bespoke event.
I suspect some other issue causing the throttle to firewall like that
