I had uninstalled whole window 10 and forget to deactivate GIT
Hi, I has some question. i already uninstall my old Win10 but i think i'm forget to deactivate GIT before uninstall... now i move to P3DV4 with new window but GIT can't work Can you help me? Thank you very much. every time i try to run my PMDG777 GIT log show yellow light and red light and log like this..
9:05:57 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
19:05:57 Simconnect Version: 3.4.0.0
19:05:57 SimConnect: Event Received: SIM, 0
19:05:57 SimConnect: Event Received: PAUSE, 0
19:05:57 Synchronising Switches & Selectors .....
19:05:57 Synchronising Switches & Selectors: Waiting for SimConnect .....
19:06:05 PMDG SDK option is OK in Prepar3D v4
19:06:05 SimConnect: Event Received: Aircraft Type Changed
19:06:05 SimConnect Message Processing Finished
19:06:06 SimConnect Connection Starting.....
19:06:07 SimConnect Message Processing Started
19:06:07 SimConnect Connection Started
19:06:07 Aircraft Connection Starting.....
19:06:07 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
19:06:07 SimConnect: Event Received: SIM, 0
19:06:07 SimConnect: Event Received: PAUSE, 1
19:06:08 Aircraft Connection Starting.....
19:06:08 SimConnect: Exception Received: ERROR
19:06:09 SimConnect: Exception Received: DUPLICATE_ID
19:06:09 SimConnect: Exception Received: ERROR
19:06:09 Aircraft Connection Starting.....
19:06:10 SimConnect: Exception Received: DUPLICATE_ID
19:06:10 Aircraft Connection Starting.....
19:06:10 SimConnect: Exception Received: ERROR
19:06:11 SimConnect: Exception Received: DUPLICATE_ID
19:06:11 SimConnect: Exception Received: ERROR
19:06:11 Aircraft Connection Starting.....
19:06:12 SimConnect: Exception Received: DUPLICATE_ID
19:06:13 SimConnect: Exception Received: ERROR
19:06:13 Aircraft Connection Starting.....
19:06:14 SimConnect: Exception Received: DUPLICATE_ID
19:06:14 Aircraft Connection Starting.....
19:06:14 SimConnect: Exception Received: ERROR
19:06:15 SimConnect: Exception Received: DUPLICATE_ID
19:06:15 Aircraft Connection Starting.....
19:06:15 SimConnect: Exception Received: ERROR
19:06:16 SimConnect: Exception Received: DUPLICATE_ID
19:06:16 SimConnect: Exception Received: ERROR
19:06:16 Aircraft Connection Starting.....
19:06:17 SimConnect: Exception Received: DUPLICATE_ID
19:06:17 SimConnect: Exception Received: ERROR
19:06:17 Aircraft Connection Starting.....
19:06:18 SimConnect: Exception Received: DUPLICATE_ID
19:06:18 Aircraft Connection Starting.....
19:06:18 SimConnect: Exception Received: ERROR
19:06:19 Aircraft Connection Starting.....
19:06:20 SimConnect: Exception Received: DUPLICATE_ID
19:06:20 SimConnect: Exception Received: ERROR
19:06:20 SimConnect: Event Received: SIMSTART, 0
19:06:20 SimConnect: Event Received: SIM, 1
19:06:20 Aircraft Connection Starting.....
19:06:22 Aircraft Connection Starting.....
19:06:22 SimConnect: Exception Received: DUPLICATE_ID
19:06:22 SimConnect: Exception Received: ERROR
19:06:23 SimConnect: Exception Received: DUPLICATE_ID
19:06:23 Aircraft Connection Starting.....
19:06:23 SimConnect: Exception Received: ERROR
19:06:24 SimConnect: Exception Received: DUPLICATE_ID
19:06:24 SimConnect: Exception Received: ERROR
19:06:24 Aircraft Connection Starting.....
19:06:25 SimConnect: Exception Received: DUPLICATE_ID
19:06:25 Aircraft Connection Starting.....
19:06:25 SimConnect: Exception Received: ERROR
19:06:26 SimConnect: Exception Received: DUPLICATE_ID
19:06:26 SimConnect: Exception Received: ERROR
19:06:26 Aircraft Connection Starting.....
19:06:27 SimConnect: Exception Received: DUPLICATE_ID
19:06:27 Aircraft Connection Starting.....
19:06:27 SimConnect: Exception Received: ERROR
19:06:28 SimConnect: Exception Received: DUPLICATE_ID
19:06:28 SimConnect: Exception Received: ERROR
19:06:28 Aircraft Connection Starting.....
19:06:29 SimConnect: Exception Received: DUPLICATE_ID
19:06:29 SimConnect: Exception Received: ERROR
19:06:29 Aircraft Connection Starting.....
19:06:30 SimConnect: Exception Received: DUPLICATE_ID
19:06:30 SimConnect: Exception Received: ERROR
19:06:30 Aircraft Connection Starting.....
19:06:31 SimConnect: Exception Received: DUPLICATE_ID
19:06:32 Aircraft Connection Starting.....
19:06:32 SimConnect: Exception Received: ERROR
19:06:33 SimConnect: Exception Received: DUPLICATE_ID
19:06:33 SimConnect: Exception Received: ERROR
19:06:33 Aircraft Connection Starting.....
19:06:34 SimConnect: Exception Received: DUPLICATE_ID
19:06:34 Aircraft Connection Starting.....
19:06:34 SimConnect: Exception Received: ERROR
19:06:35 SimConnect: Exception Received: DUPLICATE_ID
19:06:35 SimConnect: Exception Received: ERROR
19:06:35 Aircraft Connection Starting.....
19:06:36 SimConnect: Exception Received: DUPLICATE_ID
19:06:36 Aircraft Connection Starting.....
19:06:36 SimConnect: Exception Received: ERROR
19:06:37 SimConnect: Exception Received: DUPLICATE_ID
19:06:37 SimConnect: Exception Received: ERROR
19:06:37 Aircraft Connection Starting.....
19:06:38 SimConnect: Exception Received: DUPLICATE_ID
19:06:38 Aircraft Connection Starting.....
19:06:38 SimConnect: Exception Received: ERROR
19:06:39 SimConnect: Exception Received: DUPLICATE_ID
19:06:39 SimConnect: Exception Received: ERROR
19:06:39 Aircraft Connection Starting.....
19:06:40 SimConnect: Exception Received: DUPLICATE_ID
19:06:40 SimConnect: Exception Received: ERROR
19:06:40 Aircraft Connection Starting.....
19:06:41 SimConnect: Exception Received: DUPLICATE_ID
19:06:42 Aircraft Connection Starting.....
19:06:42 SimConnect: Exception Received: ERROR
19:06:43 SimConnect: Exception Received: DUPLICATE_ID
19:06:43 Aircraft Connection Starting.....
19:06:43 SimConnect: Exception Received: ERROR
19:06:44 SimConnect: Exception Received: DUPLICATE_ID
19:06:44 Aircraft Connection Starting.....
19:06:44 SimConnect: Exception Received: ERROR
19:06:45 SimConnect: Exception Received: DUPLICATE_ID
19:06:45 SimConnect: Exception Received: ERROR
19:06:45 Aircraft Connection Starting.....
19:06:46 SimConnect: Exception Received: DUPLICATE_ID
19:06:46 SimConnect: Exception Received: ERROR
19:06:46 Aircraft Connection Starting.....
19:06:47 SimConnect: Exception Received: DUPLICATE_ID
19:06:47 SimConnect: Exception Received: ERROR
If yes to both of those questions, try renaming My Documents\GoFlight Interface Tool so you start with no settings as the files may have become corrupt during the transfer.
Perhaps a re-install of the 777 now.
[SimConnect]
level=Verbose
console=No
file=C:\SimConnect%01u.Log
file_max_index=9
Start GITv4 and P3Dv4 so that the errors occur. A log file will be created in C:\ (or many log files). Copy these and attach to this thread.
