Instability problems between FSUIPC and GF Interface or PMDG ?
Hello,
Under FSX WIN7, I use a GF rudder RC, a module GF166 and a module GF TQ6 and have been monitored so far without problem with the drivers Goflight and FSUIPC. I recently bought a GF46 module and the MCP Pro, which I expect will be delivered next week. So I have installed your latest drivers and bought and installed the interface software Pollysoftware. No problem installing, the module and the joystick loads on Goflight config and the three LEDs are green on the interface .... except that after a few minutes flight there is nothing going on mainly about the TQ6 and The settings on FSUIPC change oddly, it seems that there is a conflict with GFinterface.
Thank you for your help Jean Pierre.
ENG1 and ENG2 and their reverse seem to work, but Spoilers and Flaps are inactive. I attach a file found in GFIT directory concerning the PMDG. Looking forward to reading you.
Jean Pierre
You cannot have FSUIPC and GIT "driving" the same joystick type devices simultaneously. Both programs work fine together, but if you configure the TQ6 in FSUIPC, you must disable the TQ6 in GIT (and vice versa) otherwise you will get very strange behaviour. Only one program should "drive" one device simultaneously.
See you later
As I told you in my previous message I configure and look if everything works well.
I have just received my MCpPRO which although it has been declared in GF and GFIT remains off after being turned on once.
Is there a particular procedure also to follow?
Thank you
Jean Pierre
Also make sure you have followed these instructions: http://localhost/joomla2/support/user-guide/user-guide-git/16-installation/14-installation.html
Impossible to connect on the two links you gave me.
My MCP is recognized and well declared in GF as addon. When I open GFIT the MCP is still disabled on the window although I declared it yesterday.
In fact when I open FSX the MCP only lights up one dash per digit.
When I start GFIT and before the three green LEDs are all on, the displays are zero and then turn off completely.
If I click on retsart everything goes to zero then everything goes out.
I have a similar concern with the GF46 one of which is left on.
I go through the FAQ but have not found any reprimand about me ... then your help is welcome. Thanks JP
You must also install GIT using these instructions: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/14-installation.html
The GF and GFIT are in the same directory and have installed themselves without worry ... even if the windows always show disabled peripherals ..
What more can I do?
17:46:12 SimConnect Connection Starting.....
17:46:13 SimConnect Message Processing Started
17:46:13 GoFlight Connection Started
17:46:13 SimConnect Connection Started
17:46:13 Aircraft Connection Starting.....
17:46:13 PMDG SDK option is OK in FSX
17:46:13 SimConnect: Event Received: Aircraft Type Changed
17:46:13 SimConnect: Event Received: SIM, 1
17:46:13 SimConnect: Event Received: PAUSE, 1
17:46:13 SimConnect Message Processing Finished
17:46:13 GoFlight Connection Starting.....
17:46:14 SimConnect Connection Starting.....
17:46:15 GoFlight Connection Started
17:46:15 SimConnect Message Processing Started
17:46:15 SimConnect Connection Started
17:46:15 Aircraft Connection Starting.....
17:46:15 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
17:46:15 SimConnect: Event Received: SIM, 1
17:46:15 SimConnect: Event Received: PAUSE, 1
17:46:16 SimConnect: Exception Received: UNRECOGNIZED_ID
17:46:16 Aircraft Connection Started
17:46:16 Simconnect Version: 10.0.61259.0
17:46:16 Synchronising Switches & Selectors .....
17:46:16 SimConnect: Exception Received: EVENT_ID_DUPLICATE
17:46:31 Synchronising Switches & Selectors Complete
Assuming all OK at this point, on the MCP PRO tab, select Device 0, click the FS Default button and then enable the MCP PRO in GIT. Turn the heading rotary and see if the heading display works correctly.
I did that with the 737 generic fs aircraft and the MCP worked, is should be different with Baron?
