WP6 and GF SOFTWARE TOOL problem.what happen !!!!!
2»
  • edited November -1
    hi steve
    firstly the problem is still........
    i read the
    manual and i do the steps exactly and the message of the DLL is appear
    in fsx and i click RUN (it appear as a normal process when i start the
    fsx after adding the lines to my DLL.XML file).
    and the (20:57:18 SimConnect: Exception Received:  OUT_OF_BOUN) is gone.
    here is the Log after the editing:
    22:04:11 GoFlight Connection Starting.....
    22:04:11 SimConnect Connection Starting.....
    22:04:12 GoFlight Connection Started
    22:04:12 SimConnect Message Processing Started
    22:04:12 SimConnect Connection Started
    22:04:12 Aircraft Connection Starting.....
    22:04:12 PMDG SDK option is OK in FSX
    22:04:12 SimConnect: Event Received: Aircraft Type Changed
    22:04:12 SimConnect: Event Received: SIM, 1
    22:04:12 SimConnect: Event Received: PAUSE, 1
    22:04:12 GoFlight Connection Starting.....
    22:04:12 SimConnect Message Processing Finished
    22:04:13 SimConnect Connection Starting.....
    22:04:14 SimConnect Message Processing Started
    22:04:14 GoFlight Connection Started
    22:04:14 SimConnect Connection Started
    22:04:14 Aircraft Connection Starting.....
    22:04:14 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    22:04:14 SimConnect: Event Received: SIM, 1
    22:04:14 SimConnect: Event Received: PAUSE, 1
    22:04:15 Aircraft Connection Started
    22:04:15 Synchronising Switches & Selectors .....
    22:04:15 SimConnect: Exception Received:  ERROR
    22:04:16 SimConnect: Exception Received:  ERROR
    22:04:17 SimConnect: Exception Received:  ERROR
    22:04:18 SimConnect: Exception Received:  ERROR
    22:04:19 SimConnect: Exception Received:  ERROR
    22:04:20 SimConnect: Exception Received:  ERROR
    22:04:21 SimConnect: Exception Received:  UNRECOGNIZED_ID
    22:04:21 SimConnect: Exception Received:  ERROR
    22:04:22 SimConnect: Exception Received:  ERROR
    22:04:23 SimConnect: Exception Received:  ERROR
    22:04:24 SimConnect: Exception Received:  ERROR
    22:04:25 SimConnect: Exception Received:  ERROR
    22:04:26 SimConnect: Exception Received:  ERROR
    22:04:27 SimConnect: Exception Received:  ERROR
    22:04:28 SimConnect: Exception Received:  ERROR
    22:04:28 SimConnect Message Processing Finished
    22:04:28 GoFlight Connection Starting.....
    22:04:29 SimConnect Connection Starting.....
    22:04:29 GoFlight Connection Started
    22:04:29 Synchronising Switches & Selectors Complete
    22:04:30 SimConnect Message Processing Started
    22:04:30 SimConnect Connection Started
    22:04:30 Aircraft Connection Starting.....
    22:04:30 PMDG SDK option is OK in FSX
    22:04:30 SimConnect: Event Received: Aircraft Type Changed
    22:04:30 SimConnect: Event Received: SIM, 1
    22:04:30 SimConnect: Event Received: PAUSE, 1
    22:04:30 SimConnect Message Processing Finished
    22:04:30 GoFlight Connection Starting.....
    22:04:31 SimConnect Connection Starting.....
    22:04:32 SimConnect Message Processing Started
    22:04:32 GoFlight Connection Started
    22:04:32 SimConnect Connection Started
    22:04:32 Aircraft Connection Starting.....
    22:04:32 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    22:04:32 SimConnect: Event Received: SIM, 1
    22:04:32 SimConnect: Event Received: PAUSE, 1
    22:04:33 Aircraft Connection Started
    22:04:33 Synchronising Switches & Selectors .....
    22:04:33 SimConnect: Exception Received:  ERROR
    22:04:34 SimConnect: Exception Received:  ERROR
    22:04:35 SimConnect: Exception Received:  ERROR
    22:04:36 SimConnect: Exception Received:  ERROR
    22:04:37 SimConnect: Exception Received:  ERROR
    22:04:38 SimConnect: Exception Received:  ERROR
    22:04:39 SimConnect: Exception Received:  ERROR
    22:04:39 SimConnect: Exception Received:  UNRECOGNIZED_ID
    22:04:40 SimConnect: Exception Received:  ERROR
    22:04:41 Synchronising Switches & Selectors Complete
    Something is horribly wrong here. It appears all the Simconnect commands are failing. You do have Service Pack 2 for FSX installed?
    I have the acceleration, but now i delete it and install the sp2, but the problem still,
    I am get tired, just only i need the master caution (its light & its clickable in my WP6) from the interface....
    Please help me, really its a shock. !!!!!!!
    Do any of the buttons work with different data - is it only the master caution not working?
  • edited October 2013
    I don't know any another function except the master caution,
    If you need to give another test to do, thank you and no problem.
    Just for solving the issue !!!!!
    On the first button try these settings:
    Light Colour: RED
    Button Event: ON   EVT_DSP_FO_AT_RESET_SWITCH
    Button Action: MOUSELEFT
    Light Data: DAT_FWDPAN_LIGHT_AT_LEFT
    Light Action: ON    Light Value: 1
    You can test using the Test 1/2 switch next to the bank of 3 square lights just below the EFIS.
    Hi steve:
    I do the test but the problem is still.
    Note : the simmconnet failures are still in the log also after delete the acceleration pack and install the SP2.
    What now !!!!!
    Can you tell me what the using of your WP2 panel please ????
    I don't know what's wrong. There is something odd with your setup but I can't track it down. Maybe a wipe and reinstall of FSX may help - but I can't guarantee it.
    I have PM'd you.
    I tried everything, but nothing change...
    The only thing to do now is format my computer and install everything again and see what will happen....
    I will post the result here.
    Lastly thank you so so so much mr steve about everything...
    Really y r a very very person...
    Thank you again...
    Zoher......
