X Plane 11 crash when clicking "Monitoring Toggle" with A320NEO Jardesign
Everything works on GF-45 until i want to program the buttons via Detective. When i click on "Monitoring Toggle", X plane 11 crashes.
When i start up X plane and try it again i get a crash with GIT (see screenshot).
Info: GIT 2.0.2.0.2 Xplane 11.05 64 bit, W7 Ult, GF-45, GF-P8
Andre
Andre
I tested it and had X Plane crash with Baron too when i try to use the directive. Even now with version 2.0.0.0. When i click on the Monitoring button, X plane crashed.
Will try now with 2.0.3.0.
Deinstalling GIT now
You must use 2.0.3.0 of GIT as it fixes a Detective crash issue.
Ah didn't think of it. I only deleted the plugin & Program. Will delete that one too and let you know!
So will do a clean install of 2.0.3.0 with settings file removed.
Kind Regards,
Andre
Tested with clean install on 2.0.3.0 and crashed again. Any logs that i can look into?
Kind Regards,
Andre
Keep you posted!
Some results.
1. Installed fresh X plane 11 with clean GIT 2.0.3.0 install [That works]
2. With fresh XP11 install and GIT 2.0.3.0 install. Restored ../Output/preferences folder [XP11 crashed again]
3. Restored the NEW preferences (clean version) back [That works]
4. Copied the old X-Plane.prf to the preferences folder [XP11 crashed]
5. While running GIT and restart XP11. Then click on monitoring [GIT Application Halted]
6. Left XP11 running, started GIT again [Works fine, monitoring working]
7. Left XP11 running. Copied the saved ../My Documents/Goflight Interface Tool folder back. Restart GIT [Works fine, monitoring working]
Gonna test some more and see if the Xplane.prf file has some major diff.
By the way, does the startup sequence makes a difference? (XP11 or GIT first?)
Keep you posted.
I just made a spreadsheet with indicates differences between xplane.prf which cause the crashes. I ONLY put the differences and left out the settings which are the same.
Working = Normal xplane.prf that i had when it worked
New Build = xplane.prf deleted before XP11 start. Settings from XP11 program run/close with GIT (which works)
Failed = With this xplane.prf file XP11 crashes when using GIT
Question to you, do you see setting within the difference that are influenced by GIT?
Thanks!
Besst wishes
Thanks for the support ;-)
