Additional Functions in LUA
would it be possible to add the following functions to the LUA command set please
SendKey
SendKey*
SendKeyDn
SendKeyUp
In addition, would it be possible to read the current state of any GoFlight Hardware device via LUA?
For example, one aircraft I use, uses the TAIL_HOOK_HANDLE value in P3D to flip between rudder and tiller mode.
I have a switch to toggle this, however I would, at startup, like to be able to read whatever position the T8 switch is in, and set the correct state of TAIL_HOOK_HANDLE to match the current T8 position.
  • That should be possible.
    GIT will sync the switch for you automatically. If you create two lua scripts, one for the off state and one for the on state and assign to the switch - when the aircraft loads, GIT reads the switch state and syncs the switch state with the aircraft by executing what is assigned. This works with all events, not just lua scripts.
  • I have added sendkey and sendkeyalt to GIT for X-Plane which you can download now. The other versions should have it next week.
