X-Plane FlightFactor 757 V2 EFIS + MCPPro + GF 166
This is for the new V2 version of the Flightfactor 757 -  please don't attempt to mix with the old one.
  • Thanks Steve, be a couple of days before I can try it, lot of cleaning up after our large Earthquake
  • Oh man I forgot you live in NZ. Hopefully you and yours suffered no major damage. Just saw the post from another person I know there on Facebook but I believe he lives on the south island.
  • Hi I have this working well with the 752 but not the 753 any suggestions to get it working with that one?
    Many Thanks
    Paul
  • Yes, since the aircraft name is slightly different what you need to do is shorten it's name in the profile so it will work with both models. so instead of 757-200v2017 , shorten the name to just 757. There are instructions on how to do it in the GIT documents here on this site.
  • Hi Steve
    Thanks for your reply
    I have had a look for the document you mention but cannot seem to find it
    I have shortened the name of the zip to 757 but still no joy but obviously there is more to do
    Thanks in advance
    Paul
  • Hi Paul,
    Load up the aircraft and GIT. Go to the Settings tab in GIT and shorten the name there, remembering to click OK.
  • I actually upgraded as well and it worked . Load the-200 shorten the name click no on both questions.
  • Hi Guys
    Thank you for your help
    I do as you suggest and shorten the aircraft name to just 757
    I click OK then no twice
    But it does not save and when reloading the GIT it defaults back to both 757-200 and 300
    It does work very well in the 200 but not the 300
    I am sure I must be missing something simple
    If you require any further information please just ask
    Many Thanks
    Paul
  • Try loading the 300 then import the 200 profile again using the wizard.
  • Hi just Tried that
    I now only have Zero's on the MCP and it does not interact with the aircraft
    Thank you for your support
    Paul
  • try using this. Working here. Use import wizard.
  • GIT doesn't like something. Now it won't import properly on my system with a shortened name either. Going to have to troubleshoot with Steve on this further when I have more time.
    Heading out for the day now.
  • Steve: The import is failing and leaving some BE's blank that I used in the EFIS. If I delete all BE's the reimport them the aircraft works fine for that session only. Once restart X-plane/GIT it errors out and deletes bespoke events again.
  • Hi Guys will stop struggling with the 300 till you guys have had chance to have a look at it
    Cheers
    Paul
  • I found the problem. GIT is not detecting some datarefs that it did before and since they are not listed in datarefs.txt the program deletes all the code from the offending bespoke event.
    a workaround is manually adding these datarefs to datarefs.txt and then delete/reimport again.
  • edited December 2017
    New Version - This one should work with all previous versions of the 757 and the new 757 V2 extended etc.
    The name has been shortened to work with all the variants.
  • File
  • The profile before this last one worked well today with the extended v2 200 - thank you Slayer!
  • I just noticed an issue. if you use "modern EFIS" setting in the aircraft my EFIS config doesn't work properly( I made if based on the default setting) I'll have to make a 2nd EFIS profile for the "Modern" setting as well. I knew this but totally forgot about it over the past years. Easy fix.
  • edited January 2022
    I know this is an old thread, but by using it I keep all FF757 related issues centralized, zo please forgive me.
    I am using the latest GIT for my MCPPro, EFIS, 2x GF-166 and a GF46.
    When I have the FF757-200 v2 loaded the sim crashes when doing anything in GIT. Whether it is attempting to import a profile, or just restarting GIT to get the MCPPro to work. Been working on this for a few weeks now.
    I have no problems with GIT when using any other aircraft in X-Plane 11, like the Zibo 737-800X, the Rotate MD80 and the LevelUp 737NG's
  • Do not have Update On Flight Loop ticked, if so untick it. Also it may be related to enabling Vulkan & Metal.
  • I do use Vulkan, but will have a look at the Update On Flight loop
    Thx for your reply
