P3D 4.1 anf GFIT
2»
  • non 64 bit finally loaded but not working. Looking to get my hands on that 64bit version. Running v4.1 with the NGX
  • ok was able to download and install 64bit, the testing is about to begin
  • Hi Peter
    Something very strange is going on with your setup. Your VS rotary encoder may be worn. Try this GoFlight test program for the MCP PRO and make sure everything behaves as expected: https://www.dropbox.com/s/n1hw4huebtuwgqz/MCPProChkA25.zip?dl=0
    thanks for the link. In the meantime I am back on the 32bit Version and I got the feeling that VS-Speed - Knob is working now as it should, at first glance it is working obviously better then with the 64 bit version. I dont think it is a hardware effect, with the iflyNGX and standard planes the knob is working with no problems. By the way, with the 32 bit and with the 64 but version I have three greens in GIT. At the Moment I am happy with the siuation, if further Problems arise I will check the test Programm.
    Best wishes and a happy Weekend
    Peter
