How do you set up the Goflight Data Bridge?
"If you wish to use the NGX/77X/747X in the more traditional flight simulation style, disable the LGT in GIT and configure the LGT in GFConfig making sure the Goflight data bridge runs when your flight sim starts."
How do you set up the Goflight Data bridge, and does it work for all Goflight modules or just the LGT?
Please let me know..
Thanks Rob
  • Hi Rob,
    The Data Bridge is GoFlights own software and is configured via GFConfig. GoFlights own software will only work with aircraft (or bits of an aircraft) that are Simconnect compliant.
