WP6 Auto Pilot and Auto Throttle reset switch
I am trying to set up the reset buttons for the Autopilot and Auto throttle for the PMDG 737 (P3DV4). In PMDG 737 when you disconnect the autopilot and auto throttle, a light on the dash comes on, and if you press the button associated with that light, it will go off. I am trying to duplicate that with two of the buttons on the WP6. The setup I am using (for the autopilot) is Button event "ON", EVT_DSP_CPT_AP_RESET_SWITCH Button Action "ONOff", Light Data " AUTOPILOT_MASTER", Light Action ON_GREATER_THAN Light Value 0. The problem that I am having is that when I turn off the autopilot or autothrottle in PMDG, the respective buttons light up in PMDG, but not on the WP6. If I press the buttons on the WP6, It works perfectly by turning off the lights in PMDG. How do I get the WP6 warning lights to light up when Autopilot and Autothrottle are turned off on my GFMCP PRO, in order to correspond with PMDG?
Your help would be greatly appreciated. Thanks Rob
  • edited January 2018
    Hi Rob,
    Try using DATA_FWDPAN_LIGHT_AP_LEFT instead of AUTOPILOT_MASTER.
    AT is DATA_FWDPAN_LIGHT_AT_LEFT
  • That worked perfectly - Thanks Steve
