Low Oil Pressure - Start Valve Open
On the Engines screen, when you start the engines the Start Valve Open light comes on, and goes off, when the engines reaches N2 60. When you shut down the engines, the Low Oil Pressure light comes on. I figured out how to get the Start Valve Open light to work, but cannot figure out how to get the low oil pressure light to light up, once each engine has been shut down. Can you please guide me through the process. This should be my last post, as I was able to program all my other buttons and switches. Thanks Rob
  • It looks like PMDG have not made that data available. Only the APU low oil pressure light data is available.
