Gip pipe connect Failed
Hi, i have a problem that after starting GIT and x-Plane all led´s are green then after klicking Import Wizard button and entering right aircraft zip file and clicking Import button then x-plane led blinking red and aircraft led going red as well either i try to restart GIT but stay x-plane led blinking red and aircraft led red and GIT not working and i getting in Log : this massage (Gip pipe connect Failed) has someone any clue ?
18:43:43 X-Plane Connection Starting.....
18:43:44 GoFlight Connection Started
18:43:46 GIP: Pipe Connect Failed!
18:43:49 GIP: Pipe Connect Failed!
18:43:52 GIP: Pipe Connect Failed!
18:43:55 GIP: Pipe Connect Failed!
18:43:58 GIP: Pipe Connect Failed!
18:44:01 GIP: Pipe Connect Failed!
18:44:04 GIP: Pipe Connect Failed!
18:44:07 GIP: Pipe Connect Failed!
18:44:10 GIP: Pipe Connect Failed!
18:44:11 X-Plane Connection Started
18:44:11 Aircraft Connection Starting.....
18:44:13 WinSock: Connected To localhost On Port 27015!
18:44:13 LUA Processor: Started!
18:44:13 Aircraft Connection Started
18:44:13 Synchronising Switches & Selectors .....
18:44:13 Synchronising Switches & Selectors: Waiting for X-Plane .....
18:45:03 X-Plane: Event Received: Aircraft Loaded/Flight Loaded
18:46:44 X-Plane: Event Received: Aircraft Loaded/Flight Loaded
18:46:47 LvarNamesUpdated!
18:46:47 Creating Bespoke Vars
18:46:47 Bespoke Vars Created
18:46:47 Importing Bespoke Variables
18:46:47 Bespoke Vars Assigned, Importing Bespoke Events
18:46:47 Bespoke Events Temp Imported
18:46:47 Bespoke Events Imported
18:46:47 Loading Aircraft Settings
18:46:47 GetXMLConfigData
18:46:47 GotXMLConfigData
18:46:47 Loading Power
18:46:47 Loading MCPPRO
18:46:47 Loading EFIS
18:46:47 Loading P8
18:46:47 Loading T8
18:46:47 Loading RP48
18:46:47 Loading MESM
18:46:47 Loading WP6
18:46:47 Loading LGT
18:46:47 Loading LGT II
18:46:47 Loading GF46
18:46:47 Loading GF45
18:46:47 Loading TQ6
18:46:47 Loading DIO
18:46:47 Loading GF166
18:46:47 Loading SECM
18:46:47 Loading Joysticks
18:46:47 Clearing Displays
18:46:47 Reset Data
18:46:47 Aircraft Settings Loaded
18:46:47 Calling Aircraft Changed
18:46:47 Aircraft Changed
18:46:48 XPlane: Event Received: Sim State 1
18:46:50 Synchronising Switches & Selectors Complete
18:46:47 Reset Data
Confirm both the display and switches are not working on the MCP PRO with the default 737.
The pictures, do not show the device 0 chosen. Can you do that for the MCP PRO and do a screen dump of it.
I confirm that both display and switches are not working
I chose device 0 for both of them and tried again but still MCP PRO not working
Can you rename Documents\GoFlight Interface Tool to Documents\GoFlight Interface Tool Old so that we are starting with a clean config. Then run the import wizard, but just select the MCP PRO and not the EFIS and let me know what happens.
