Best Rigard
Almost every time I see that GFDEVHWTYPE_ error message it is mostly due to a failed import, corrupted file or an aircraft got updated and it can't find the dataref anymore.
This sounds like a windows permissions or Defender issue. Is he running under an admin acount on his PC? Have we excluded Xplane folder and GIT folders from Windows defender or other antivirus?
That would be my guess.
before i update the IXEG GIT its worked. now as you know i have to deactivated GIZMO64 to run GIT with x-plane aircrafts.
have you loaded the IXEG without git to make sure its activated?
I think you might have to manually copy over datarefs.txt and commands.txt to the aircraft folder because if it can't see some datarefs the profile will not work
Naser - can you disable all other addons except for GIT and the IXEG and see if that helps the issue. Could you also attach the Commands.txt and Datarefs.txt files from the IXEG aircraft folder so I can check they are correct.
Best regards
Naser
Slayer - can you point me to some free scenery that uses autogate so I can track down the error and fix that particular issue.
PS: I have added more checks and error reporting into the forthcoming new version of GIT which may shed some light on what is going wrong for you with the IXEG.
A new version of GIT is available for download which I think will fix your problems. Download from your account in the normal way.
Have nice weekend
