  • It is the GoFlight Interface Tool setup file.
  • Ok thanks, I download the software (GTI) and I only get one green light the other ones are red, do you have a step by step process how to make this work with X-Plane 11 and Zibo 737? I loaded the software twice the second time I disabled the firewall. Still not working.
  • Also I get a message of "pipe connect failed"
  • 08:06:57 GoFlight Connection Starting.....
    08:06:57 X-Plane Connection Starting.....
    08:06:58 GoFlight Connection Started
    08:07:03 GIP: Pipe Connect Failed!
    08:07:09 GIP: Pipe Connect Failed!
    08:07:15 GIP: Pipe Connect Failed!
    08:07:21 GIP: Pipe Connect Failed!
    08:07:27 GIP: Pipe Connect Failed!
    08:07:33 GIP: Pipe Connect Failed!
    08:07:39 GIP: Pipe Connect Failed!
    08:07:45 GIP: Pipe Connect Failed!
    08:07:51 GIP: Pipe Connect Failed!
    08:07:57 GIP: Pipe Connect Failed!
    08:08:03 GIP: Pipe Connect Failed!
    08:08:09 GIP: Pipe Connect Failed!
    08:08:15 GIP: Pipe Connect Failed!
    08:08:21 GIP: Pipe Connect Failed!
    08:08:27 GIP: Pipe Connect Failed!
    08:08:33 GIP: Pipe Connect Failed!
  • It sounds like the plugin is not running in X-Plane. During GIT installation, did you check the directory was correct for the plugin installation. If so please check the folder exists under plugin\resources in x-plane.
  • What is the name of the folder?
  • GIT Plugin
  • Reinstall and chose the plugin file but no change, not working.
  • What aircraft are you using? Did the Log tab show any errors after running the import wizard?
  • I am running the Zibo 738, in the Interface pic it shows b738 that I download from your site (profile), it sees the GoFlight unit but it does not talk to them, is it because Globaldata ref red X. Also the DRE mimic Mode is red. I use these units few years ago with Microsoft Sim and they all worked nicely. Your software seems a bit complicated.
    Thanks for your help.
  • edited April 2018
    What about the log?!?!
    Please run the import wizard again and see if any errors appear. If there are errors, please post the log here.
    Are there any errors in the Log tab when first starting GIT?
    You also need to physically remove the DataRefEditor plugin from the plugins folder to get the DRE Mimic Mode to go green.
    PS: Make sure you have read and followed the install guide here: https://www.pollypotsoftware.org.uk/support/user-guide/goflight-interface-tool-x-plane/33-installation/78-installation.html
  • DataRefEditor from X-Plane 11 or the Zibo 738?
  • X-Plane 11
  • thank you I will try it.
  • You will need to run the import wizard again once removed.
  • log
    09:14:13 GoFlight Connection Starting.....
    09:14:13 X-Plane Connection Starting.....
    09:14:14 GoFlight Connection Started
    09:14:15 X-Plane Connection Started
    09:14:15 Aircraft Connection Starting.....
    09:14:15 X-Plane: Event Received: Aircraft Loaded/Flight Loaded
    09:14:17 WinSock: Connected To localhost On Port 27015!
    09:14:17 LUA Processor: Started!
    09:14:17 Aircraft Connection Started
    09:14:17 Synchronising Switches & Selectors .....
    09:14:17 Synchronising Switches & Selectors: Waiting for X-Plane .....
    09:14:21 LvarNamesUpdated!
    09:14:21 Creating Bespoke Vars
    09:14:21 Bespoke Vars Created
    09:14:21 Importing Bespoke Variables
    09:14:21 Bespoke Vars Assigned, Importing Bespoke Events
    09:14:21 Bespoke Events Temp Imported
    09:14:21 Bespoke Events Imported
    09:14:21 Loading Aircraft Settings
    09:14:21 GetXMLConfigData
    09:14:21 GotXMLConfigData
    09:14:21 Loading Power
    09:14:21 Loading MCPPRO
    09:14:21 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFMCP 0 0 0 LIGHT - Specified argument was out of the range of valid values.
    09:14:21 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFMCP 0 0 1 LIGHT - Specified argument was out of the range of valid values.
    09:14:21 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFMCP 0 0 2 LIGHT - Specified argument was out of the range of valid values.
    09:14:21 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFMCP 0 0 6 LIGHT - Specified argument was out of the range of valid values.
    09:14:21 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFMCP 0 2 0 LIGHT - Specified argument was out of the range of valid values.
    09:14:21 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFMCP 0 2 1 LIGHT - Specified argument was out of the range of valid values.
    09:14:21 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFMCP 0 2 2 LIGHT - Specified argument was out of the range of valid values.
    09:14:21 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFMCP 0 2 3 LIGHT - Specified argument was out of the range of valid values.
    09:14:21 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFMCP 0 2 4 LIGHT - Specified argument was out of the range of valid values.
    09:14:29 Loading EFIS
    09:14:29 Loading P8
    09:14:29 Loading T8
    09:14:29 Loading RP48
    09:14:29 Loading MESM
    09:14:29 Loading WP6
    09:14:29 Loading LGT
    09:14:29 Loading LGT II
    09:14:29 Loading GF46
    09:14:29 Loading GF45
    09:14:29 Loading TQ6
    09:14:29 Loading DIO
    09:14:29 Loading GF166
    09:14:29 Loading SECM
    09:14:29 Loading Joysticks
    09:14:29 Clearing Displays
    09:14:29 Reset Data
    09:14:29 Aircraft Settings Loaded
    09:14:29 Calling Aircraft Changed
    09:14:29 Aircraft Changed
    09:14:30 XPlane: Event Received: Sim State 1
    09:14:32 Bespoke Start Event Running
    09:14:32 Global LUA Event Running
    09:14:32 Global Aircraft LUA Event Running
    09:14:32 Synchronising Switches & Selectors Complete
  • Looking in the forum, the zibo config file is for version 3.25B of the aircraft. Is that the version you have installed?
  • Hold on! I have just noticed from your pictures that you have an MCP and not the MCP PRO. The config file is for the MCP PRO - hence why it isn't working!
  • Zibo V3.24H running
    What this note means:
    Thank you
  • I guess you missed my previous answer?
  • your software let me change to MCP only but now I can not change anything to GoFlight unit.
  • The config file for the Zibo is not built for the MCP (only for the MCP PRO) - its never going to work!
  • ok, can I get a refund?
  • No - see the T&C's.
    The customer supplied Zibo download will not work with the MCP (only the MCP PRO) but you can build your own config for the Zibo and the MCP - that is what the product is all about - its an interfacing tool.
    David Williams is a customer who built the MCP PRO config file for the Zibo and if you ask him here on the forum, he may assist you in building the MCP config for the Zibo.
  • How can I get in contact with him?
  • This is his original post of the Zibo files. https://www.pollypotsoftware.org.uk/vanillaforums/discussion/706/zibos-b737-x-plane-3-10o-alpha/p1
    He is the first poster on page 1.
