GIT file
what is the GIT file?
08:06:57 X-Plane Connection Starting.....
08:06:58 GoFlight Connection Started
08:07:03 GIP: Pipe Connect Failed!
08:07:09 GIP: Pipe Connect Failed!
08:07:15 GIP: Pipe Connect Failed!
08:07:21 GIP: Pipe Connect Failed!
08:07:27 GIP: Pipe Connect Failed!
08:07:33 GIP: Pipe Connect Failed!
08:07:39 GIP: Pipe Connect Failed!
08:07:45 GIP: Pipe Connect Failed!
08:07:51 GIP: Pipe Connect Failed!
08:07:57 GIP: Pipe Connect Failed!
08:08:03 GIP: Pipe Connect Failed!
08:08:09 GIP: Pipe Connect Failed!
08:08:15 GIP: Pipe Connect Failed!
08:08:21 GIP: Pipe Connect Failed!
08:08:27 GIP: Pipe Connect Failed!
08:08:33 GIP: Pipe Connect Failed!
Thanks for your help.
Please run the import wizard again and see if any errors appear. If there are errors, please post the log here.
Are there any errors in the Log tab when first starting GIT?
You also need to physically remove the DataRefEditor plugin from the plugins folder to get the DRE Mimic Mode to go green.
PS: Make sure you have read and followed the install guide here: https://www.pollypotsoftware.org.uk/support/user-guide/goflight-interface-tool-x-plane/33-installation/78-installation.html
09:14:13 GoFlight Connection Starting.....
09:14:13 X-Plane Connection Starting.....
09:14:14 GoFlight Connection Started
09:14:15 X-Plane Connection Started
09:14:15 Aircraft Connection Starting.....
09:14:15 X-Plane: Event Received: Aircraft Loaded/Flight Loaded
09:14:17 WinSock: Connected To localhost On Port 27015!
09:14:17 LUA Processor: Started!
09:14:17 Aircraft Connection Started
09:14:17 Synchronising Switches & Selectors .....
09:14:17 Synchronising Switches & Selectors: Waiting for X-Plane .....
09:14:21 LvarNamesUpdated!
09:14:21 Creating Bespoke Vars
09:14:21 Bespoke Vars Created
09:14:21 Importing Bespoke Variables
09:14:21 Bespoke Vars Assigned, Importing Bespoke Events
09:14:21 Bespoke Events Temp Imported
09:14:21 Bespoke Events Imported
09:14:21 Loading Aircraft Settings
09:14:21 GetXMLConfigData
09:14:21 GotXMLConfigData
09:14:21 Loading Power
09:14:21 Loading MCPPRO
09:14:21 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFMCP 0 0 0 LIGHT - Specified argument was out of the range of valid values.
09:14:21 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFMCP 0 0 1 LIGHT - Specified argument was out of the range of valid values.
09:14:21 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFMCP 0 0 2 LIGHT - Specified argument was out of the range of valid values.
09:14:21 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFMCP 0 0 6 LIGHT - Specified argument was out of the range of valid values.
09:14:21 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFMCP 0 2 0 LIGHT - Specified argument was out of the range of valid values.
09:14:21 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFMCP 0 2 1 LIGHT - Specified argument was out of the range of valid values.
09:14:21 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFMCP 0 2 2 LIGHT - Specified argument was out of the range of valid values.
09:14:21 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFMCP 0 2 3 LIGHT - Specified argument was out of the range of valid values.
09:14:21 ImportDynamicPropertiesToXML: Exception occurred for device GFDEVHWTYPE_GFMCP 0 2 4 LIGHT - Specified argument was out of the range of valid values.
09:14:29 Loading EFIS
09:14:29 Loading P8
09:14:29 Loading T8
09:14:29 Loading RP48
09:14:29 Loading MESM
09:14:29 Loading WP6
09:14:29 Loading LGT
09:14:29 Loading LGT II
09:14:29 Loading GF46
09:14:29 Loading GF45
09:14:29 Loading TQ6
09:14:29 Loading DIO
09:14:29 Loading GF166
09:14:29 Loading SECM
09:14:29 Loading Joysticks
09:14:29 Clearing Displays
09:14:29 Reset Data
09:14:29 Aircraft Settings Loaded
09:14:29 Calling Aircraft Changed
09:14:29 Aircraft Changed
09:14:30 XPlane: Event Received: Sim State 1
09:14:32 Bespoke Start Event Running
09:14:32 Global LUA Event Running
09:14:32 Global Aircraft LUA Event Running
09:14:32 Synchronising Switches & Selectors Complete
What this note means:
Thank you
The customer supplied Zibo download will not work with the MCP (only the MCP PRO) but you can build your own config for the Zibo and the MCP - that is what the product is all about - its an interfacing tool.
David Williams is a customer who built the MCP PRO config file for the Zibo and if you ask him here on the forum, he may assist you in building the MCP config for the Zibo.
He is the first poster on page 1.
